01.13.2007, 03:10 PM
The 17mm and 23mm is only referring to the hex size. A standard Maxx for instance, is 14mm and tend to strip easily with brushless. If you don't have either 17 or 23mm rims, I prefer 23mm (because of all the rims to choose from), but with all the 17mm rims out, it really doesn't matter anymore...I have a few sets of 23mm and no 17mm, so I just stick with 23.
01.13.2007, 05:06 PM
I used 14 cells and a lehner 1950 and didnt have a problem with stock revo hexes.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
01.13.2007, 05:28 PM
It mainly depends on your rims...
01.13.2007, 05:30 PM
the huricanes should be fine with stock hexes.
01.13.2007, 06:56 PM
Personally, if this is gonna be a race truck, and you want the ultimate in durability, reliability, etc, get the RD setup...
01.13.2007, 08:17 PM
I had all kinds of problems with the stock rims/tires on the Revo, but a set of good maxx-size wheels (extended offset for more width) has held up great. I've never stripped a hex yet and I've run it hard. You really have to make sure the wheels are tight on the shafts; I can see them stripping for sure if they get loose.
01.13.2007, 08:42 PM
Brian, did you ever bend an axle stub? I don't really run my trucks that hard, yet I bent a couple...
01.13.2007, 10:00 PM
Nope. It must be difficult to do that. The only way I can see it happening is to slide sideways into a low wall (curb) or something at speed so that the bottom of the wheel is forced in, but usually this breaks an axle carrier if anything.
01.13.2007, 10:29 PM
It's actually not hard to do. :005: Alot of racers had that problem (I'm guessing from hitting the wall, pipes, and jumps wrong) so thats why they developed the 8mm axle kit.
RC-MONSTER BRUSHLESS FANATIC
01.14.2007, 12:23 AM
thanks for all your responses, i really like this forum because you guys help out a lot,i do appreciate you guys for your time.
I will be posting pics on some of the parts that i already have. this will probably be an update for the making of my erevo.This will also serve as a reference for those who wants to build thier own E revo versions especially for racing.
You guys have any news for the up coming revo slipperential and 1/8 diffs?
01.14.2007, 12:35 AM
I was breaking axles carriers for that reason until I got the RPM ones. Everything seems to be holding up fine now. I really hope I don't start breaking axles because the RPM carriers came with new, different size bearings and I would have to replace those again if I got the 8mm axles. BTW: where do you get the new 8mm axles??
01.14.2007, 12:51 AM
What do you guysthink about those aluminum extension wheel adaptors that increases the width into 1 inch on each side fora total of 2 inches in width?
01.14.2007, 01:20 AM
That would do nothing but cause problems. Mainly the bearings and axles...Bent axles and ruined bearings are a certainty...
01.14.2007, 01:23 AM
I agree with squee. If you want a little wider stance, I'd go with a rim with a little offset. It won't give you 2", but it will certainly help stability and put less strain on your axles bearings, and steering servo(s).
01.17.2007, 03:56 PM
Hres some of the pics ,it is in the progress,still considering neu if my budget will be enough,waiting for the slipperential and 1/8 diffs, iwill be using 2 packs of 4800 lipos
