SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.21.2007, 08:53 PM
This thread is really mixed up:
First of all a 7700 on any fully charged 7.2 volt battery will make the tires balloon out of control when lifted in the air. It doesn't take that much power to do so, just a lot of rpm. Unless your EPA is not set correctly, you must have a mislabled motor.
2. High kv motors do not have less torque than lower kv motors. Torque is a function of amps which are mostly limited by the battery.
3. The fastest setup would be the 4600 on 4s lipo and U-bec. You will easily be able to beat a stock jato with this setup. Even the 5700 on 3s will be able to beat a jato, though it might overheat.
4. The 4600 on 4s is most likely faster than a 7700 on 3s despite the rpm difference.
Area 52 Ranch Raceway
T.R.C.R.
