crazyjr
crazyjr's Avatar
01.22.2007, 04:55 PM
Originally Posted by t-maxxracer32
what do those do for the truck? here are the settings on cl
brake amount-50
punch control-100
start power-low
no cutoff
reverse-50
drag break- disabled
motor timing- normal
throttle curve is stock. what does this setting do?
brke curve is stock. what does this setting do also?
Try this, it worked for me.
punch 50%
start power low
timing lowest
the timing is the worst for causing heatup
set your cut-off to 5v so the current doesn't go high and cause heatup
go to a 17 tooth gear and it will help a lot
