hyperasus
hyperasus's Avatar
01.23.2007, 07:15 PM
Ok I bought a Bushnell Velocity off ebay for $69.99. Hopefully it should work.
jhautz
jhautz's Avatar
01.23.2007, 07:33 PM
Anyone use GPS for speed testing? Anyone have any sugestions as to a good, small, light GPS unit for strapping into a truck?
to make it...
or break it...
Silent...But Deadly
01.23.2007, 07:47 PM
If you use a GPS, make sure it has a fast enough sampling rate to be accurate. The Garmin I have in my car seems to update every second. In an R/C, you could hit a top speed that may not register on the GPS unless it is sustained.
MetalMan
MetalMan's Avatar
01.23.2007, 10:37 PM
I use a Garmin eTrex, and it too seems to update only once a second. When you're at full throttle for only 1sec. because you don't have much room during a speed run, it can be frustrating.
