neweuser
neweuser's Avatar
01.29.2007, 02:51 PM
Originally Posted by E-Revolution
But im suprised... I have think if use more celss than Castle Creations site read, controller get smoked. But if i can use 4-5s LiPo without smoked, i buy some other LiPo than Max Amps 11.1v 8000mAh:dft009:
It's mainly the bec in the esc. what the guys are doing is using an external bec called a ubec. This will allow more voltage to be run through the esc. You do need to watch temps and what not though, make sure your gea ing is right. There are limitations to everything of course. Also, I think if you are running more than 4s is voiding warranty. But yes, it can be done.
