neweuser
neweuser's Avatar
02.01.2007, 03:53 PM
I have the MTR's. They really don't balloon as much and I didn't tape mine at all, the ribs are not only on the inside of the wall, but they go around the tires as well. The sidewall ribs make the sidewall a tad stiffer to reduce sidewal flex. Also, the sidewalls aren't narrower as in height, but they are width wise compared to the reg MT tires.
the ribs do add weight which I did not like too much. I would use the non-offset velo's...
Bomb-Proof
02.03.2007, 06:17 PM
The MTRs have less sidewall because they are narrow tires, they ballon like any others.
Pick a narrow tire (any of the MTR's) and a lightweight wheel. Set up suspension with 50% sag. Use a super fast servo. Do this and you will be running with the best of them.
neweuser
neweuser's Avatar
02.05.2007, 10:31 AM
I disagree, they do balloon, but not as much as ANY tire. They balloon less than the MT's as well.
But go with the MTR's and velo 0% offset, you'll be golden. Also, I run the bowtie's, but from my experience, the CF's hook up better on the track.
