Originally Posted by strodedawg
if by jumper you mean the red and black wire form the receiver plug then yes.
There should not be any plugs removed from the controller's receiver leads. If these are removed, reinstall and try again. To program - both the black and red jumpers should be removed. Upon completion of programming(before unplugging the batteries), the red jumper gets reinstalled. Unless I am misreading this, it seems like you pulled a couple leads from the controllers rx lead, which may be the trouble(and would explain why you have the same problem with any radio you try).
