glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.29.2007, 11:53 PM
Nice work... what would be sweet is to find a CVD type center shaft that is the proper length. The diff end would fit the modded center diff outdrive and the other end would have the u-joint, which I'm guessing would work on the other end? (assuming the .5 is made like big brother...)
But... you can probably make the custom shaft like in your pic. I cut a dogbone and shortened it for my Kyosho conversion. I used whatever material I could find that fit the bill... I think it was an aluminum handle from a pick. And I used a piece of steel tubing also, then put pins through it. Amazingly it's worked great... it's not the prettiest thing, but it has not failed yet. :)
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
