08.25.2008, 04:12 PM
Not sure if MGM will send me a new unit for free
My setup was e-revo, with RCM hybriyd diff (buggy ratio) geared 62/22, on 6s li-po
I've run about 5 hour with this setup before the controller catch in fire.
Don,t know the reason
08.25.2008, 06:11 PM
6s lipo is presumably 6 cell which at 3.7 volts per cell equates to 22.2 volts, the 16018 is rated as per model number suggests at 18 volts so your running it over it's limit. I was going to go with the 16018 until I realised that it would restrict me 4/5s so I ordered the 16025.
This may not have been your problem but I wouldn't rule it out.
 Losi 8T RR - Novarossi Plus 21-5BT/ Jammin JP3 - Teknorc 8T - Neu 1515-1Y - MGM 16025-3 Z Series ESC.
08.25.2008, 06:26 PM
Sorry but you're not right my friend, the 16018 is rated for 6s li-po or 18 cells ni-mh.
18 cells ni-mh = 21.6V
6s li-po = 22.2
The 16018 can support 25V.
So i was not running over limits
08.25.2008, 06:33 PM
Play with my e-revo for an hour or more this week-end without any problem.
Today, i've plug the pack and give it a little run, and in about 3 second after niail the trottle, ........... Poufffffff!!!! some white smoke around the revo. So i remove the body to see a beautifull and big, big flame on the controller
I've un-plug the li-po to save it from the fire.
The negatif input lead have boke inside of the board and short on the input capacitor.
I hope that my 2 li-po pack are correct, i've not try to recharge it.
So i nead a new controller. Maybe a MMM or another MGM i don't know.
David,
Forget the MGM!!! Cut your losses and go with the MMM.
Originally Posted by 83gt
I don't think it's that rare. I smoked my 16018 in pretty much the same fashion. It worked great for several runs, and then released the smoke on plugging in the battery the next day. Strange. It worked for a while after that only on external BEC or RX pack, and then it shot some little flames when the fets went up.
J.
I had exactly what David and yourself have explained happen to me. Sad thing is when I sent the unit back to MGM for a warranty repair I was slugged with a $120 (AU) repair bill  . I will be selling my MGM when it gets back and getting a MMM as soon as Mike has them readily available.
Cheers Andrew
08.25.2008, 06:35 PM
 ouin david go with the mmm
08.25.2008, 06:38 PM
the "18" number isnt the amount of voltage it can take but the number of NiMh cells it can handle....so the voltage was fine
08.25.2008, 07:12 PM
My mistake s I apologise, I'm sure it won't make any difference in that case but as MGM have a 16025 listed I went with that instead of the 16018, it'll probably still go up in smoke at some point!
Soldermaster Extraordinaire
08.25.2008, 07:15 PM
David, I'm sorry for your loss.
MGMs are very robust controllers, as I'm sure most of us know, however they aren't perfect and (unfortunately) still fail once in a while. My 16016 has been serving me well for the last 3 years. Even with the 2.32 firmware (I don't use reverse).
08.25.2008, 08:13 PM
What about the 224.18 and the 160.24 controls...do they ever go tits up?
08.26.2008, 05:26 PM
Hi David - can you please describe what method you used to measure the internal resistance of your cells? I'm curious to know what you used for the shunt - i've been trying to figure out a good shunt for lipos in order to really give them a workout on the bench.
Thanks!
08.26.2008, 05:35 PM
Thanks!
I think David would be taking the reading from his charger. Some of the better chargers now days will give you a read out of resistance etc.
Correct me if I'm wrong David.
Cheers Andrew
08.26.2008, 05:39 PM
You're right Country!! I've an Hyperion 0610i DUO.
08.26.2008, 05:38 PM
You are not wrong, but there arent that many that have that feature so far as I know.
GorillaMaxx G3 Carbon
08.27.2008, 09:02 AM
I got my MGM 16024-3 fan cooled from Mike not long ago, hooked it up and sparks+smokes. Undid the battery as quick as I can. removed the fans and found one of the screws for the fans had a burnt tip. Left the fans out, hooked up the battery again, no sparks or smoke, able to programme it with the USBCOM++, ran my HV4400 motor freely (not installed to truck) A123 4S1P battery. Bolts everything into the truck, hooked up again, and much more sparks and smoke. MGM 16024 now on its way back to Czech Republic.
Save the environment, GO BRUSHLESS.
08.27.2008, 09:40 AM
Welcome in my MGM jungle.
For me, i
Never spend $300.00 again on a supposely High End controller. I have order an MMM and if this MMM died, so i am sure that i will have a fast support from Castle. It is not the same thing for MGM, the delay to have a response to the email is very long, and the delay to ship it oversea is realy too long.
