Byte
10.12.2008, 04:39 AM
Stick with 5 or 6s. I have found that my 4500 30c 6s lipos are close to maxed out with the hacker 11xl. I am not sure if the 1521 will draw less amps, really do not think it will. I would stick with the 4900 5s pack and a lower kv motor.
Ok, what about 2x3s? NEU Energy 4900mAh 3s 25-50C? And a NEU 1521 with 1900Kv?
That would be good I think?
10.12.2008, 07:44 AM
Step down to the 1521 1y and you should be fine, just gear it for the speed you want. The motor has so much torque there is no need to rev it any higher.
10.12.2008, 12:34 PM
Sounds like a great conversion. If you don't have the dough for the 1521, check out the Mega 22/45/2 for 6s.
Byte
10.12.2008, 05:49 PM
Ok, thank you for all your advises Lincpimp! Thanks for all the great help! Now I just need to get the money ok, I have it, but I want to work for the money. So next month or something I will buy the motor. 1 month later the LiPo's, and finally the ESC.
All other guys also thank you for helping me!
Just a little list:
- Losi LST2
- NEU 1521 1Y
- NEU Energy 25-50C 2x3S 4900mAh
- Mamba Monster Max
- RC-Monster 2 Speed pinion adapter 5mm bore
- Self made motor mount
- Self made Battery tray
Again: Thank you for helping me!
EDIT: Another thing, I forgot the name for connecting those 2 LiPo's together. Something like: ...-Kabel
I want one with Deans, does somebody know one here on rc-monster?
Byte
10.29.2008, 02:18 PM
Ok, finally, I got my LST! :D
But, I had a discussion with a friend of me.. He said that I will lose speed if I have a 2 speed gearbox, but he wasn't sure.. So, what do you guys think? And another question, I'm a noob at nitro, but could someone say me what the 2nd servo does? ( The one above on the picture )
Thanks!
brushlessboy16
brushlessboy16's Avatar
10.29.2008, 07:36 PM
Pretty sure the second servo is either Hi/low range or reverse
Byte
10.31.2008, 06:24 PM
Already got it, its idd reverse!
Ok, a new problem!
I saw a topic with a guy, that already killed 5 MMM's! I DON'T want that happen to me! So, I'm searching a good ESC. What do you guys recommend? The motor will be a NEU 1521 with 1900Kv, and 2 x 3's 4900mAh LiPo, so 22,2V!
I saw some MGM's, I thought this wouldn't be a bad ESC: http://mgm-compro.com/index.php?tid=...-boat-e-series
Or are the continious/peak amps to less?
And another question, do you think I could better buy a MGM or MMM? (Or maybe a other ESC)
Please tell me! I'm really confused! :S
Joram
Nitro?? BL rulezzz
11.01.2008, 12:31 PM
Hoi Patrick ook hier aan het posten? Kom eens op msn, kunnen we elkaar helpen, zijn toch met bijna hetzelfde bezig.
We are dutch so just a joke
Well, there is now the MM V3, i'm gonna use that one because the MGM'S are tricky too. So i just decided too choose for the CC service IF there's something wrong with the ECS. (i was very positive about the MM so..)
Greetz,
Joram
Standard is not an option!
  Send a message via MSN to Joram
Mozzy
Mozzy's Avatar
11.02.2008, 10:18 AM
That's definitely reverse & if you get hold of a "Forward only" conversion from Losi you'll be shedding weight from the truck. Mainly, that servo you asked about & alot of metal weight in your trans. I think it sheds about 300gm when you go forward only.
I'm sending 6 MM's back tomorrow. 3 failed after they refused to update the new software to fix the problems CC techs found, go figure. The other 3 basically failed in my truggy, all just went offline permanently.
Now I have none.
Steering servo & receiver works though.
Losi SCTE SC4 Pro 4000kv, Tekin RX8, 2S
MP7.5 Kanai III Tekno Neu 1515/2.5D 1700kv MM 4S
LST 2 Carbon CC 1717 1Y 1580kv MM 6S
Futaba 3PKS Spektrum Pro
