02.12.2009, 12:11 AM
Turn the ccbec around so that the input wires go between the MM and the ubec. Leave a bit more space between the ccbec and the mm, like 1/4 - 1/2 inch. That way you can put the output wire of the ccbec in the loom and it will be kept away from the input wires. I have a setup that looks identical save for the ubec is oriented as I suggest, and it works fine, FM radio too! Plenty of range, no issues.
bdebde
That's All Folks!
bdebde's Avatar
02.12.2009, 12:12 AM
Originally Posted by hoovhartid View Post
I think you would want to lower the motor timing and possibly raise the start power in the linc settings
Yep, I second that.
02.12.2009, 01:08 AM
The CCBEC is a little noisy from tests. I would at least try relocating temporarily to see if that helps. Maybe even use an Rx pack just to see.
If the cogging/stuttering is worse further away, I would suspect radio interference. If range was not an issue, I'd look more at ESC settings. I assume the MM has version 1.2 firmware? That helps a lot. Then, increase start power (helps tickle the motor faster so the ESC can get a good commutation signal), and maybe increase punch control (help rule out low Q battery).
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
02.12.2009, 03:12 AM
i missed the part about it happening more when at a longer range.
that changes things a bit
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
02.12.2009, 07:32 AM
Thanks for your input guys....I think I will try to move the bec a tad first to see what happens, then I will fiddle w/the esc..
"helps tickle the motor faster" My favorite part...
