jnev
jnev's Avatar
05.03.2008, 08:34 PM
I would be in for a 12s ESC. I have always wanted to try HV as the highest I have gone is only 4s. But with the MMM, I will probably try it to 6s, and if the HV ESC came from CC, I'd try a 1/5 scale truck conversion too.
dubkatz
05.03.2008, 10:30 PM
the thing is 6s and a good efficient motor is gonna push(Plenty fast) any 1/8 buggy, truggy, monster truck no matter how much aluminum you have on it, and thats what the mmm is ment for. not to power custom 1/5 scale 25lb monster trucks. I run 14 old beat up, vented gp33000's. that on a 9xl is almost too much power for all but strait speed runs. keeping it on all 4's off the line is a chore, unless i loosen the sliper a whole lot. So someone tell me why 6s with a neu isnt gonna be enough? :P
05.03.2008, 10:45 PM
Well, for a start, higher voltage generally runs cooler, and allows for cheaper lipos, as the c rate and overall size can be smaller. Until you have run a hv setup it is difficult to understand the difference. Also, depending on the lipo, the lower amp draw due to increased voltage provides more performance at higher motor loads, as the batteries are not working as hard as a 4s setup would be. 6s is good, much better than 4s in my experience. Plus the cheaper feigao motors seem to run cooler at higher voltages, as their is less current going thru them. The higher voltage helps the ineffecientcy of the motor a bit.
lutach
lutach's Avatar
05.03.2008, 11:04 PM
lutach
lutach's Avatar
05.03.2008, 11:18 PM
Simple:
Lets say you're looking for 2HP or 1500 watts. With 6S you will need at least 68A to get that. Now if you had 12S all you would need is 34A. With 6S a good motor for a buggy would be the 1512/2.5D and for 12S would be a 1512/2.5Y. Now if you want a good motor for a truggy with 6S would be a 1515/2D and for 12S a 1515/2Y. Now those would be a nice choice for racing. Guess which motors will be more powerful, run cooler and more efficient.
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
05.04.2008, 02:32 AM
That doesn't explain why 6s wont be enough. All your saying is that 12s is better than 6s, while you don't prove how much of an advantage there actually is (where is your actual data?) Not everyone is trying to break the land speed record with a monster truck. I would be more concerned about lipo failures than having a setup that runs 20 degrees cooler than what is already acceptable. The more cells there are in a pack, the more vunerable the cells are to undervoltage, since a weak cell has to go way below the safe limit before the mean voltage of the cells in the pack triggers the cutoff.
Area 52 Ranch Raceway
T.R.C.R.
azjc
05.04.2008, 02:52 AM
With higher voltage you can run a lower KV motor and this setup will pull less amps meaning less heat than a lower voltage and higher KV motor, and since your motor is pulling less amps with the higher voltage setup you can run a lower capacity pack to get the same runtimes. Your motor will pull a certain amount of watts all the time, Volts X Amps = Watts, the average 1515 or XL size BL motor will pull 1500 watts, if you want to compare different setups you can divide the 1500 by the voltage amounts and this will get you in the ball park there are other variables Gearing, weight of vehicle, wheel size.
lutach
lutach's Avatar
05.04.2008, 03:15 AM
Originally Posted by azjc View Post
With higher voltage you can run a lower KV motor and this setup will pull less amps meaning less heat than a lower voltage and higher KV motor, and since your motor is pulling less amps with the higher voltage setup you can run a lower capacity pack to get the same runtimes. Your motor will pull a certain amount of watts all the time, Volts X Amps = Watts, the average 1515 or XL size BL motor will pull 1500 watts, if you want to compare different setups you can divide the 1500 by the voltage amounts and this will get you in the ball, park there are other variables Gearing, weight of vehicle, wheel size.
Right on. Plus the lower Kv motor will have more torque. This concept is true with brushed and brushless. The more turns you have the higher the torque. The less turn the higher the Kv. Most people usually runs HV for speed runs mainly because of the added bonus the HV provides for high speed runs. If one has a 100A 12S controller and he runs at the AMP limit, he'll be getting over 4000 watts of power. Now if he wants to race and changes the gearing for around 40mph, I'll bet he'll only see spikes of maybe 80A and only on hard acceleration, but he will average around 20A or so instead of 50A+ with less voltage.
lutach
lutach's Avatar
05.04.2008, 03:09 AM
I can't prove to anyone who hasn't done a efficient HV set up yet. I ran my 1521/1.5Y with 10S lipos geared the same as my 1521/1Y and everything ran just warm. Now with the 1521/1Y on 6S everything runs much warmer. You have things mixed up and it shows that you have never ran anything above 6S. You still think only because one wants 12S he'll be trying to set a record. How can I set a record on 10S with a 1521/1.5Y since the unloaded RPM is 38850. I ran my 1521/1Y with 10S and it was awesome, but that motor is at it's best with my 6S and it's unloaded RPM is 35009. Now with 10S on the 1521/1Y I saw spikes of 169A, but after 9 minutes of running the truck the average was only 10A and I only used 1685mAh out of 4600mAh. I haven't posted data yet of the 1521/1.5Y plain simply because of me running the 1521/1Y with my 6S packs that I'm trying to get as many cycles as I can to test how good they are. If you want I can give you some data of my 1521/1.5Y on 10S in a couple of days. Lipo failure are most common by users not following simple rules. Good lipos hardly fail under the right conditions. The only lipos that I had that failed under the right conditions was my MA packs. All the others were abused by me. Most people need to learn that HV is not for speed only. Ask the folks who does have a HV set up not for speed. They will tell how good things run. Some folks are even running a 55A controller on 10S and having great results. It's just simple common sense and experience with HV that proves to people how good it is.
05.04.2008, 11:58 AM
Ok, I will say that for most situations that 6s would be fine in a mt geared for around 40mph. Given a sytem properly setup for 6s and another that has a motor with half the kv on 12s, the 12s setup will pull half the amps that the 6s does, and produce more torque. Plus the batteries can be half the capacity and provide the same runtime (most likely more). I am sure that a expernisve motor in a hv setup will run cooler, but not so cool as to fail. Most find a feigao xl to be ineffiecent, and heat up to much, such as a 7xl on 4s. I run a 14xl on 8s lipo and it performs fine, in a heavy savage, and I use a 60amp air esc that barely gets warm. Plus I can get away with 12c lipos, my 3600 polyrc lipos only cost 120 bucks (30 each for 2s 3600 12c packs x 4). I would love to see another 120 dollar lipo compare to this setup in either 4 or 6s. The lower loads placed on the cells by a hv setup will help the cells stay in balance. High current draw is what causes cells to come out of balance. Hv just makes sense for larger,heavier vehicles. More torque, less load on the battereis, and cooler running with cheaper equipment. For me hv is the only way to get a feigao to work properly, but then they are great value!
captain harlock
RC-Monster Captain
captain harlock's Avatar
05.04.2008, 10:05 AM
Patrick, PLEASE, man.....I've been waiting all of my life for a HV car controller beside those schulze and BK rubbish. I've tried several escs from castle creations besides the mamba max and they are bulletproof.
I'm also in for one, whether 8s or 12s( the latter is surely better, though).
And BTW, Patrick. I've spent 450 dollars on a 149.18 controller from schulze, 420 dollars on a 89.24 controller from schulze,430 dollars on a 220/32 controller from MGM and couple of thousands on other escs. That doesn't mean I'm rich( I usually stay for 6 months untill I could afford one of them....I've been looking for the ultimate controller from that time without luck.
Now maybe I'll finally find my query in your pocket, man.
Bring it on, please!!!
Nice to meet you!
DrKnow65
DrKnow65's Avatar
05.04.2008, 10:35 AM
Here is my reasoning for wanting HV, how many amps do you realy want to make your expensive lipo's put out? Lets say you have a well performing RC that is pulling 1200 watts, not insane speed but enough to lift the front tires.
12S=44.4v / 1200w=27 amps (1250mah)
6S=22.2v / 1200w=54 amps (2500mah)
3S=11.1v / 1200w=108 amps (5000mah)
Will your lipo's, motor, and ESC be safer and last longer at 27,54, or 108 amps? Simple math.
lutach
lutach's Avatar
05.04.2008, 11:06 AM
That is simple enough and others have said the same thing. I can't agree more with you DrKnow65 and finally more people are understanding why I keep bugging for a HV controller, but still we have those who can't get it. You know whats even better. You can use a 2500mAh 12S pack and get close to 1hr of solid cool run time with your math and that's just amazing. I even went the extra step and found the only company willing to do it and they are doing it from scratch. It won't be as good as the other HV controllers for cars, but it'll get the job done. With the Castle HV for cars, it will be just awesome to have a great company who has shown us just awesome products have one as well.
05.04.2008, 11:54 AM
It seems to be a bit of a common mis-conception that higher voltage = more insane power and speed, and it simply isnt the case. Higher voltage can mean that, certainly, but what it really means is a slower turning motor can be used that leads to longer run times, lower temps, and cheaper batteries. The only downside I can find is the need for more space on the chassis for batts maybe, and a higher voltage capable charger maybe too- no biggie.
lutach
lutach's Avatar
05.04.2008, 12:41 PM
There are good and inexpensive chargers out there already. I charge my 2 5S Thunder Power packs in parallel using my AF 109. The current electric conversions are the ones putting limits on the batteries used. I showed suicideneil my chassis designs and they'll be made for HV application. You can easily fit 12S in them and if you think 12S is too much, just use 6S. It will be a well balanced chassis.
