RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.01.2005, 10:47 PM
The warriors(9920 and 12020) should both be back in stock(with Plenty) within a couple weeks.
The 9920 controllers usually have only one set of wires(thick), but some have had two sets. the recent ones had one set, though(Nick). The 120 amp and larger controllers have the double wire.
mothman
11.01.2005, 11:42 PM
So do you mean that I missed the 1st shipment :(?? Ive signed up for the notice but didnt get any msg from rc-monster.com. So Mike can you put me on the list for the next shipment?? Not going to miss them again.
By the way do you have the Wanderer in stock?? If not are they going to come with the Warrior?
RC-Monster Mike
Site Owner
11.02.2005, 01:12 AM
Wanderers will be along with the warriors. If you recently signed up for notification, you haven't missed anything. The 9920s, 12020s, and a few wanderer motors will be along soon. I should have enough to go around this time!
toby
toby's Avatar
11.02.2005, 07:46 PM
okay, i need a straight answer, no beating around the bush.
Those blue wires, first
why is there two to each wire lead.
does it matter which two go to which motor lead?
rc18mt/blade cp
coolhandcountry
coolhandcountry's Avatar
11.02.2005, 08:03 PM
it matters to a point. If you keep the wires in pairs like coming out the esc you fine. That should give you the sets to connect to the three wires of motor. that part does not matter fat as which set to each wire of motor.
Peace!
Country
Help support the
Rc-Monster
Buy here
toby
toby's Avatar
11.02.2005, 08:04 PM
so as long as the blue wires stay in the pairs they are they can go to any lead? i am still trying to find somewhere to mount this thing
rc18mt/blade cp
coolhandcountry
11.02.2005, 08:12 PM
yeah toby. If the motor spins backwards to the way you need it. Swap two of the three wires and it will be right.
Peace!
Country
Help support the
Rc-Monster
Buy here
toby
toby's Avatar
11.02.2005, 08:45 PM
umm, i am direct soldering though, kind of a difficult thing to do, there is no way to do it right the first tiem? and how would i know which wires to swap?
rc18mt/blade cp
coolhandcountry
11.02.2005, 09:30 PM
Any two wire of the three will work. It does not matter.
Peace!
Country
Help support the
Rc-Monster
Buy here
squeeforever
squeeforever's Avatar
11.02.2005, 09:55 PM
also, if your direct soldiering you can always do it another way. all you have to do is have the batteries plugged in and pull the red programming jumper off and then if it beeps that is telling you that it is switched directions. then just put it back on.
RC-Monster Mike
Site Owner
11.02.2005, 10:52 PM
If you direct solder, simply do as squee said. this info is also in the "how to program your BK controller" post.
toby
toby's Avatar
11.03.2005, 12:23 PM
where is that red program jumper thinger? i see a red thing beside some wires but it is covered by shrink wrap on the esc
rc18mt/blade cp
Gustav
Gustav's Avatar
11.03.2005, 12:34 PM
The red one is behind the red battery wire on the bottom of the controller under the the shrink wrap.the black one is behind that and in a bit.
Papa
Papa's Avatar
11.03.2005, 12:35 PM
If you look at my thread, wiring, there is a photo on the first page. The jumper is under the positive wire on the 9918.
toby
toby's Avatar
11.03.2005, 02:22 PM
alright, i carefully cut out some of the wrap around it to get at it just incase. thanks guys,
rc18mt/blade cp
