93firebird
08.12.2010, 09:41 PM
I'm not sure if piano wire is hard enough. I use it in my Crawlers. This truck has a ton of torque, and is capable of doing standing back flips.
Dj_Sparky
08.13.2010, 03:48 PM
Hey, how did you mount the center diff? And what center diff did you use? The standard? And what spur gear? I'm trying to make a GST conversion as well, but not sure on how to mount the center diff! :)
Could you post a few more pics, especially of the center diff setup? I've been asking all around the web for some specifics on how to do this, so I'm hoping you can help! :D
As far as the pins.. I bought a new 23mm adapter set for another car, but I believe I ended up using the pins from that set in the GST. They are really thick and need to be pounded through the hole.
93firebird
08.13.2010, 08:04 PM
I just made a custom mount based around the Matrix TR mounts, and the one found here on the Monster store for the motor mount. I used some aluminum stock found at Lowes, 1/4" steel brake line for spacers and various hardware found at the LHS. I used the 66t spur from the matrix tr mounted to the center diff out of the genesis trans. I don't know how much more info I can give, it's been a a year or so since I built it.
Dj_Sparky
08.13.2010, 10:50 PM
Ah ok, thank you. Got some pics of the setup? Can't really see much of the center diff from the pics already posted.
