shaunjohnson
i pwn nitro
shaunjohnson's Avatar
08.13.2009, 03:19 AM
oh my bad
i didn't think it'd be possible to dye something that is...oh wait...rpm make dye able arms don't they?
  Send a message via MSN to shaunjohnson
Foxracin
08.13.2009, 09:21 AM
Originally Posted by shaunjohnson View Post
oh my bad
Yea, they offer most of there stuff in a dyeable white option.
Kevlar
Kevlar's Avatar
08.14.2009, 12:48 AM
Carriers arrived...and they are sharp!! But no CVD's with em, oh well.
Man are these sweet, such a great reduction of wheel slop...wish my bearings and lipos would get here.....
It takes a big hammer to drive a big nail...
Mentat
Brushless Mentat
Mentat's Avatar
08.14.2009, 06:37 AM
You will not be disspointed with turnigy packs, i have zippy, turnigy, enerlands, hyperions, thunder power and i have to say that the turnigys are about the best there are. I havent looked at the soldering tho. I honestly think tho that my 4s1p 5000mAh 25 turnigy is as good if not better then the 40c thunder power of the same spec. Enjoy. I also have thos servos, they are a beast. I just wish there were more servos that had the upper part aluminum as well as the bottom, like the high voltage JRs out there. Its so much easier to not have to worry about the plastics part of the servo getting broke or bent.
Like this:
FS: 8ight-t Race Roller TONS of UPGRADES
8ight 1.0 & 2.0 | 8ight-T 1.0 & 2.0 | E-Revo BL Edition | T-Maxx | Slash | Raze-ST | XXX-NT Drake | 3PKS | DX3S Telemetry
Kevlar
Kevlar's Avatar
08.14.2009, 01:43 PM
Those servos look awesome, and must perform as good as they look.. something else for me to look into..
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.14.2009, 01:53 PM
Hitek HSR-5990TG Robot servos (416.61 oz.in @ 6v) that have the plastic top and bottom, I have several in my trucks and never broke one ? What are you doing to have to worry about breaking the cases ?
Your Revo looks nice, all the red is different than the norm.
The Tekno carriers work really great, A buddy of mine bought a set and I'm considering them myself.
Mentat
Brushless Mentat
Mentat's Avatar
08.15.2009, 03:53 AM
I havent broken any of the casing, but they do wear after a while and will eventually break or get that white crease if you over tighten. just a pain that it is plastic is my thing. for the price that most of the servos out there cost they should be ALL aluminum.
Mentat
Brushless Mentat
Mentat's Avatar
08.15.2009, 03:54 AM
thing about those servos above are that they can use 7.4v without any type of regulator. full 2s lipo! and hella large torque, there is a speed model too. $199 tho!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.15.2009, 07:56 AM
These (Hitek HSR-5990TG Robot servos) are rated to handle 7.4 as well and are 129.99 depending where purchased.
http://www.rcplanet.com/Hitec_HSR_59.../hrc35990r.htm
Size: 1.57" x 0.78" x 1.45" (40 x 20 x 37mm)
Weight: 2.39oz (68.00g)
Torque: 333.29 / 416.61 oz.in (6v/7.4v)
Speed: 0.17 / 0.14 sec @ 60 deg.
Operating voltage: 6.0 to 7.4V
Max speed: 0.17 sec/60 degrees at 6.0V
0.14 sec/60 degrees at 7.4V
Stall Torque: 24.0kg.cm (333.29oz.in) at 6.0V
30.0kg.cm (416.61oz.in) at 7.4V
Operating Angle: Max 180 degree
Connector wire length: 300mm (11.81in)
Kevlar
Kevlar's Avatar
08.17.2009, 10:09 PM
Some batteries came, only the 2s's, hoping the 4s's and Acers come soon....just charging the second pack now then for the test run....
Foxracin
08.17.2009, 10:54 PM
How well do they fit in the battery compartments with the wires coming out the side?
Kevlar
Kevlar's Avatar
08.17.2009, 10:57 PM
Not very well, I cut out a bit of the door and it closes just fine and stays shut, I don't know if cutting the shink wrap and exposing more wire would work, I don't want to risk it until I see a pic of someone else doing it. I will be exploring all options...
WORST VIDEO EVER..but you get the point...
isuck@rc
08.18.2009, 05:07 AM
i have one for project noob, arrived yesterday, should have noob and the tekin revo runing with photos within the fortnight- both chassis are dyed now bud
Kevlar
Kevlar's Avatar
08.18.2009, 08:31 AM
Nice! I've been buying parts to dye for another build, looks like that will be the way to go since I haven't found a G3R CF chassis around. Also I had to tighten my slipper clutch after that vid, and did another run, way more bite now but still need to get some street tires to get some better traction for those short test runs...
SV6000
SV6000's Avatar
08.18.2009, 10:08 AM
Hi Kevlar PM sent
CUBIC INCHES = CUBIC HORSEPOWER = CUBIC DOLLARS
