e-mike
e-mike's Avatar
11.01.2008, 01:03 AM
Originally Posted by stum View Post
Yes I have the e-revo
22/58 on a 4s setup in the erevo is about 54mph on the top end.. considering the 4s 8000mah is the longest running config
16/58 is nice for racing ~40mph on 4s (rpms at about 40k)
ive try this set-up but my lipo come realy wwwwwottt(160f)and it was a pair of maxamps 7.4 8000mah,,,,lowest timing.....this is why i switch to 6 cell...geared 14/68,,,im borderline(rpm) but my lipo are cold(97f)motor 150f after 30 minutes and esc 112f
D8t on juice!!
stum
11.01.2008, 01:12 AM
The 8k packs don't typically get super hot until the last 1000mAH, if you are geared hot, I mean over 18/58 I wouldn't take the lipos to the LVC. I know what you mean about the temps though, I had one of my MA 8k packs poof a touch when running it hard to LVC also, but I was geared at 22 at the time. One pack was fine 130ish, the other was 150, mA replaced for free (warranty). I will say expecially with the 1.5d you need to be geared conservative to keep the amp draw down.. but high voltage is another good way to keep the amp draw lower as well :)
big greg
11.01.2008, 05:57 AM
specially considering the packs you are running.
those packs are the best tho, enerland cells! if he had the r's which i think so. i run mine next to my polyquest, exact same
johnrobholmes
johnrobholmes's Avatar
11.03.2008, 11:29 AM
MA carrying enerland cells? Not likely.
---JRH---
hoovhartid
Monster Bottle Opener
hoovhartid's Avatar
11.03.2008, 01:44 PM
i thought he was refering to the zippy's
<a href=http://i87.photobucket.com/albums/k137/darrajsam/bottomline.jpg target=_blank>http://i87.photobucket.com/albums/k1...bottomline.jpg</a>
I used a "bottom" line.
bustitup
11.03.2008, 04:16 PM
ya I smell something...and its just not right
castlemike
11.06.2008, 12:46 PM
That would just be a typo when he said new version. There is no V4............
bustitup
11.06.2008, 12:55 PM
I'm going to change my evil ways in the future and be much less agressive
so would a demagnitized motor cause a esc to go bad?
castlemike
11.06.2008, 01:16 PM
The obvious answer would be..........yes :)
bustitup
11.06.2008, 01:19 PM
ok just got off the phone with Odette at Neu...the motor is being shipped out tomorrow
Pdelcast
Pdelcast's Avatar
11.06.2008, 11:23 PM
Better safe than sorry... Always good to have these things checked out.
Patrick del Castillo
President, Principle Engineer
