stum
11.01.2008, 12:27 AM
I wouldn't gear a 1.5d over 22/58 for regular use.. maybe a bit more for speed runs and such but if you are doing some serious bashing or racing that is the MAX. Racing is best around 16-19t/58 depending on your track size/layout. Typically being geared right on or just under 40 will result in the best lap times. I'll agree those packs coulnd't handle the amps you were pulling, and it resulted in the failure. Gear that thing lower.. specially considering the packs you are running.
