Lipos in Parallel
fordman
Lipos in Parallel - 02.17.2008, 10:18 PM
Hello,
Can you run two lipos in parallel even if one of the packs has a smaller diameter wire? FYI, both packs are exactly the same except for the power lead diameter.
sikeston34m
sikeston34m's Avatar
02.17.2008, 10:20 PM
Yes IMO you can.
I run Lipo's in parallel quite often. I don't think the wire size will make that much difference.
sikeston34m
02.17.2008, 10:22 PM
One thing I want to add.
Just be sure they are about the same voltage before you hook them together.
If one is a few 10th's of a volt different, then it's ok.
Just don't hook a dead one to a fully charged one.
fordman
02.17.2008, 10:55 PM
LOL, I did that once.
Thanks for your help Sikes.
dklst
02.20.2008, 07:27 AM
do u have a diagram of running them in parrallel? that will increase the runtime rite? Is there any other benefits?
sikeston34m
02.20.2008, 08:29 AM
Check out Brians page here: http://www.scriptasylum.com/rc_speed/_lipo.html
scroll down to the section "Battery Pack Wiring". Then click on "use 2 parallel battery packs"
Yes it will increase runtime by doubling the available mah's of capacity.
Let's say you are running 2 packs parrallel. Each pack is a 10C 4S1P 4000mah Lipo capable of 40 amps continous discharge.
In Parallel, they will supply 4S voltage at 8000mah and be able to deliver 80 amps continous working together.
I hope this helps.
