Antenae length??
notnodak
Antenae length?? - 03.12.2008, 02:32 AM
I purchased a Losi DSM out of a Mini Slider to put in my Brushless Maxx to hopefully fix the range/glitching problem. When I recieved it today I noticed the antenae is only about 3" long from case to end. If I put this in my reciever box(3905Maxx) it'll stick out maybe an inch. Can I just add to it so I can get to the antenae tube and just make it long enough to stay under the body or won't it matter? I'll test it tomorrow to see but I don't like surprises
Sammus
Sammus's Avatar
03.12.2008, 02:35 AM
I had one on my mlst2 that I just let lay flat on the body - worked like a charm. no need for a tube.
I think antennae length are tuned for a particular frequency or something, so I wouldnt mess around changing it. 2.4Ghz all seem to use much shorter antennae as well
tashpop
03.12.2008, 07:09 AM
just leave it as is.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
notnodak
03.12.2008, 09:28 AM
My only concern is that it barely gets out of the Rx case an inch
Sammus
Sammus's Avatar
03.12.2008, 09:33 AM
I dont think thats a concern... let it hang out, or curl it up inside, shouldn't matter, unless your rx case is lined with lead :P
notnodak
03.12.2008, 09:44 AM
No, no lead but that Kriptonite might be an issue.
teamhelotes
03.12.2008, 12:54 PM
The 2.4 gz are made to have a super short antena. Just leave it like it is. If you want just put a 1" tube on it.
notnodak
03.12.2008, 03:57 PM
So far alls good but I had to tuck the whole thing under the Rx cover. I'll test more today and tomorrow to be sure. I need to make sure the radio and ESC are linked up correct
TexasSP
Something, anything, nothing
TexasSP's Avatar
03.13.2008, 12:34 AM
I run my futaba 2.4ghz antennas usually right along the chassis. Best reception out of anything I have ever owned so I don't think you will have a problem.
www.cubicle101.com
