LBA10 balancer keeps switching modes
gtxracer
HOOH HUAH HOOH! Aww Baby!
gtxracer's Avatar
LBA10 balancer keeps switching modes - 03.21.2008, 06:27 PM
My LBA10 keeps switching modes when I'm charging. It will do the same thing when balancing. All of a sudden, it just stops, and has a solid red light on cell 1. What gives?
Oh, and this is on 4s with the 1210i.
:D
gtxracer
gtxracer's Avatar
03.23.2008, 10:54 AM
I think I might have blown one of the cells in the LiPo but I'm not sure. Someone HELP!!!
I don't know how I could have done it.
:D
Blunten
03.23.2008, 11:38 AM
Have you tried balancing another lipo? If the bat not the problem, go ahead and open up your balancer and see if that button is loose.
gtxracer
gtxracer's Avatar
03.23.2008, 12:39 PM
I don't have any other LiPos, but the 1210i still charged some NiMh cells I have, so it has to be the battery or the balancer.
Are you talking about the mode button?
:D
Blunten
03.23.2008, 03:28 PM
Yeah, the button might be loose
gtxracer
gtxracer's Avatar
03.23.2008, 03:47 PM
I took it apart and it looked fine, so I'm gonna give it another test.
:D
crazyjr
crazyjr's Avatar
03.23.2008, 04:49 PM
I got the same problem with an 8000 2s maxamps lipo i got. after talking to someone from maxamps, we determined that due to the age of the battery, a cell was dying. I let the balancer run for overnight and it finally balanced. What is probably happening is the same as me, Mine is a 2p, not sure about you. But the good cell is overcharging and causing a safety cut-off. Mine did with different balancers and chargers. I let it balance overnight, topped it off then took an hour to balance then topped it off again and it balanced almost immediately. I was told it would be safe till it fails to balance or it swells
gtxracer
gtxracer's Avatar
03.23.2008, 05:22 PM
That might have been what happened. I balance and charge my packs correctly, so it might have happened during the run. It's been charging fine, but very slowly at the last 5%. I've taken it off to balance it a few times when it slows. I think it's fine, we'll see on the next run.
:D
bluonyx
03.23.2008, 05:27 PM
I had to balance my brother-in-laws lipos and one cell on each was very unbalanced. It was a solid red light for at least an hour on one and almost 3 on the other. I jsut left them alone and it eventually started to blink, then flash quickly. When the cells balanced it just shut off. I re-read the instructions and it said that it's ok to leave them plugged in all night. I have a LBA6.
While it was discharging I put it in an ammo box with a ziplock bag of dirt on top, just in case. If it does blow it just melts the bag and then the dirt smothers the flames.
