Switching B.E.C. on monster max
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
Switching B.E.C. on monster max - 05.12.2008, 09:37 PM
Hi guys is there a switch for the bec on monster max? or is it on 5.5 volts default setting ?Do i need to ajust it's BEC? By the way i just got my 2 escs today and will give report on it's performance once i got it running,will be running on maxamps 5000 mah 3s lipo (2) in series on a Neu 1515 1.5D (1700kv motor) in my Jammin truggy that will be use for racing
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
jhautz
jhautz's Avatar
05.12.2008, 09:40 PM
MMM has a fixed 5.5V bec in it. Its not adjustable like the CCBEC.
The adjustability was bad info.
Let us know how they run.
to make it...
or break it...
Silent...But Deadly
05.12.2008, 10:32 PM
Good luck with those lipos...
TDC57
TDC57's Avatar
05.13.2008, 01:31 AM
I’ve got a stupid question for the team,
Can you simply disarm the existing BEC and add an external one / (IE) CC10amp one??
Thanks for your time
Shaun.
Nothing!.. Hahahahaaa..
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
05.13.2008, 02:42 AM
Shaun.
Same question here and would there be any benefit?
rccna.com
TDC57
TDC57's Avatar
05.13.2008, 04:14 AM
Two that I can think of off hand.
1. The MMM has 5. amps BEC were the other one for $17.00 is 10+ amps (twice the protection)
2. The CC external 10 amp BEC has been out for while and has proven itself to be a good buy and that it actually works well.
Not bashing the MMM in any way here team, I'm just thinking that it worth it to me to spend the extra $20 not have to experience any down time.
its me
its me's Avatar
05.13.2008, 04:22 AM
My thoughts exactly!! I would rather spend the 20 something dollars and have fun then smoke the internal bec and have to deal with it.
Will the cc bec be able to handle 2 4s lipo's in parallel?
rccna.com
JeffEmbracedDC
JeffEmbracedDC's Avatar
05.13.2008, 06:39 AM
You can have as many cells in parallel as you wish. Parallel connections will increase the capacity. However, if connected in series it will maintain the same capacity, but increase the voltage! So make sure to hook them up correctly.
-Jeff
BL 8ight, BL FT B44, BL FT TC4, BL FT T4
  Send a message via Yahoo to JeffEmbracedDC Send a message via AIM to JeffEmbracedDC Send a message via MSN to JeffEmbracedDC
