My BL e-maxx is finnally able to be ran!!
A RC Dude
A RC Dude's Avatar
My BL e-maxx is finnally able to be ran!! - 06.11.2008, 03:17 PM
ok here it is:
i love deans and costom parts!
and i love wires too!
It's only 2WD for now but soon it will be 4WD with a fan on the ESC and FLM bulks as well. so it's not compleat, but i can still run it!! It's 13lbs and has RPM upper and lower arms all the way around. I also made my own costom wheelie bar, 3.3 slider shaft for the center, ESC mount, and a fan mount for the motor as well (soon i will have a costom fan mount for the ESC too). I have also installed 3.3 diffs, knuckles, and sliders all the way around. other than that, i installed the RPM true track conversion kit and the CC BEC.
so i know it's not compleat but, what do u guys think?
Robert
06.11.2008, 03:42 PM
Take it out and get it dirty :)
brushlessboy16
brushlessboy16's Avatar
06.11.2008, 05:45 PM
u need a slipper cover ;)
A RC Dude
A RC Dude's Avatar
06.11.2008, 09:10 PM
Robert, i tryed but my batts didn't run well at all. i'll try again tomarrow after i charge and discharge the batts a few times. Thay have been sitting for a long time.
Brushlessboy, i tryed to put my gear cover on but it wouldn't fit becouse of the screws holding it on the slipper are sticking out too far.
BL_maxx
06.12.2008, 03:54 AM
what motor is that???
jnev
jnev's Avatar
06.12.2008, 10:29 AM
I am pretty sure it is a Feigao 9xl...
A RC Dude
A RC Dude's Avatar
06.12.2008, 10:43 PM
Yup, jnew got it just becouse we know each other on another forum
A RC Dude
A RC Dude's Avatar
06.13.2008, 05:17 PM
well i got a good chance to run it today. and the batteries aren't performing too well. the problem is that it has the same amount if not a tinny less power now than it did when it was running with brushed motors! the top speed is pritty much the same tho. and on top of that, the fan got jamed so i had to unplug it. when i unpluged it, the motor got up to about 160 degrees wile the ESC was only running about 150 or so. the only thing worse than that is that the batteries got up to about 210+ degrees!
A RC Dude
A RC Dude's Avatar
06.13.2008, 09:26 PM
well, i ran it again today! it's running a little better except for the overheating. i didn't get it run it long tho becouse of this:
A RC Dude
A RC Dude's Avatar
06.18.2008, 05:21 PM
well, i fixed the drive shaft and now my MM ESC is fried again!
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
06.18.2008, 05:29 PM
Looks good, how many times have you fried your MM?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
A RC Dude
A RC Dude's Avatar
06.20.2008, 10:22 PM
3, one time it was my MM motor in my rustler that coused it. the 2nd time was also in my rustler but the motor was perfictly fine. this last time it did it with my 9XL.
and BTW, the maxx is 4WD now and has a pritty good wheelie bar that i just made to replace the old 1
skellyo
skellyo's Avatar
06.20.2008, 10:26 PM
Did you bypass the internal BEC on the MM? It sure looks like you didn't from the pics in your original post.
BL_maxx
06.21.2008, 12:58 AM
yeah it doesnt look like you did and you also have the ubec on there too.
A RC Dude
A RC Dude's Avatar
06.21.2008, 05:50 PM
How could I bypass the internal BEC on the MM?
