Mugen MBX4-RR Conversion!
Mugen MBX4-RR Conversion! - 07.08.2008, 12:05 AM
Hey guys, new project here. Just bought this:
http://www.rcuniverse.com/market/item.cfm?itemId=412096
Planned setup will be: Medusa 36-50-2200, MM, 5s on 12/46 gearing with the Mugen MBX5 mount and custom battery tray. Here's the exported values.
Differential Ratio: 3.3333333333333335
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 12
Total Voltage: 18.5
Motor KV: 2200
Tire Diameter (inches): 4.6
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.007
Spur/Pinion Ratio: 3.83 : 1
Total Ratio: 12.77778 : 1
Tire Circumference (inches): 14.45 inches (367.06 mm)
Total Motor Speed: 40700 RPM
Vehicle Speed: 43.59 mph (70.02 km/h)
Estimated Adjusted Speed: 41 mph (66 km/h) - 6% loss
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
Give me your opinions. Pics will be taken upon arrival.
07.08.2008, 12:23 AM
Do you guys know if the Mugen MBX5 mount is compatible with the MBX4?
Takedown
WARNING: May become violent.
Takedown's Avatar
07.08.2008, 12:43 AM
DAMN YOU! I just had dibs on that same buggy... Anyways good luck with the conversion. Looks to be yet another killer setup!
RIP- Tammy (9/14/08)
07.08.2008, 12:44 AM
Thanks?
Takedown
Takedown's Avatar
07.08.2008, 12:45 AM
It was a compliment. Didnt mean to be harsh but that was one helluva deal!
07.08.2008, 12:46 AM
I know. Just trying to "spark come interest." I really hope the MBX5 mount works with the MBX4.
big greg
07.08.2008, 01:13 AM
wow that was a good deal, and you got the noisey engine to sell off
Matthew_Armeni
Matthew_Armeni's Avatar
07.08.2008, 01:26 AM
Dude, 5s with the Medusa 2200kv 50mm will be insane! You'd be better off running 4s, it'll still be plenty fast and torquey. It's what I'm running in my 8ight buggy and it's a great setup. If you already have 4s batteries give them a try before you go 5s.
  Send a message via AIM to Matthew_Armeni
Takedown
Takedown's Avatar
07.08.2008, 01:28 AM
5s with the 2000kv 36-60 is the perfect setup. 4s will be to low of voltage for my tastes...
brushlessboy16
brushlessboy16's Avatar
07.08.2008, 06:50 AM
Direct drive!
Takedown
Takedown's Avatar
07.08.2008, 09:16 AM
Direct drive is kinda a thing of the past right now ben. Its not efficient but has power and most people want a balance between the two.
07.08.2008, 09:33 AM
http://www.rc-monster.com/forum/showthread.php?t=13381
I assume it is the same car...
brushlessboy16
07.08.2008, 09:50 AM
yep.
Takedown
Takedown's Avatar
07.08.2008, 11:34 AM
Yep, same one.
07.08.2008, 11:38 AM
Actually, the engine did not come with the truck.
