CRT.5 Body Posts
lucias
lucias's Avatar
CRT.5 Body Posts - 07.16.2008, 05:42 PM
I was lookign for some more body posts for my CRT.5 and all I could find is this?
http://www3.towerhobbies.com/cgi-bin...I=OFNC0676&P=7
Is there another option besides buying what on the link?
VintageMA
VintageMA's Avatar
07.16.2008, 05:52 PM
I would get this one:
http://www.amainhobbies.com/product_...ducts_id/13447
It is the direct part kit for the CRT.5. Includes two front mount and two rear mounts.
Also - someone recommended to me mounting the front mounts in reverse (ie: screws in from the front) and even though I had to cut two new holes in the body and the mounting isn't totally perfect I have yet to bust a body post for a while.
“Everyone has a right to be stupid; some people just abuse the privilege.”
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
07.16.2008, 05:55 PM
So your after aluminum?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
lucias
lucias's Avatar
07.16.2008, 05:58 PM
I would buy some aluminum ones.. they would last longes as I am a stellar driver.. I mean wrecker! Do they make any?
lucias
lucias's Avatar
thats the kit I was looking for..
Thanks for the Tip..
07.16.2008, 06:41 PM
Just use a set of stampde / rustler mounts - Cut them off and drill a hole through - Cheap as chips and last a good deal longer
Finnster
KillaHurtz
Finnster's Avatar
07.16.2008, 10:41 PM
I busted the tops off mine fast (flips and lid slides on pavement) and as I have the ext chassis, none of the parts for the ext version can be found.
So.. I cut the stumps off flat and drilled and tapped a 3mm hole thru the post and used 3mm cap head bolts instead. Tons of wrecks and no breaks.
You can see it here if you squint:
Shark413
Shark413's Avatar
07.17.2008, 12:43 AM
Or how about these. Got tired of replacing the plastic mounts when they broke or got ground off.
Losi 2.0 8ight-E / Losi 2.0 8ight-E/T / jammin SCTRC10 / Slash 4x4 PE
