Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Dace Adapters and 8mm UE CVD's
gusti
Dace Adapters and 8mm UE CVD's - 10.14.2005, 12:06 PM
Guys
Today I got the wheels from Dafni, he did a fantastic glue job for me. Thank you Dafni.
First I have mounted the dace on the wheels, this works pefectly. Than I tried to mount the complete wheels on the truck. This is impossible.
The reason is very simple. I am using the 8mm UE CVD's. So the CVD has a 5mm winding with a 10mm screw nut. So the diameter outside of a 10mm wrench is 14.2 mm, but the diameter of the hole from the dace adapter is 12.8mm. For this reason I can't tighten the nut.
Guys I had so much misfortune with this supermaxx, this is unbelievable. Does somebody of you have an idea how I can solve this problem.
I went to a special screw shop and was asking for a 5mm winding nut with 9mm outside diameter. But this is not available, because the dealer told me such a nut will not hold.
I went to the website from UE. On this side I have seen this, these are the dace adapters
http://www.unlimitedengineering.com/...3502T4x23.html
How does this work, for me it seems impossible.
Thank you for your support.
