My MMM lives, but I have an issue.
Darion
Question My MMM lives, but I have an issue. - 09.10.2008, 02:12 PM
Ok, so I finally got to install my MMM in my truck and got it calibrated no problem. Decided to get things going by just running a 2s 25c 5000 lipo to see what was what. Dialed a few things in and the truck was running great, was getting wheelies with just the 2s pack.
On to the issue. As I was running in the backyard I ended up spinning the pinion gear so the truck come to a hault. The pinion sort of got caught at the end on the motor shaft and the front diff case, wedged in. Got everything out and re-set-up, no apparent damage, only to find that the motor is stuttering to the point where it will not move, it did not do this at all before. Check all my connections and all looks and tests good. Tried a different battery and it didn't make a difference. The thing is I have no ring tones now from the motor, I did before, but the MMM is checking out fine. BTW, the motor is a Feigio (spelled wrong?) 8xl and is new. I had no heat issues, nothing was more than just warm, had only ran for less than 10 minutes.
So, think the motor took a shit or am I over looking something?
Thanks for the help,
Darion
