Bent hinge pins?
maxxdude1234
maxxdude1234's Avatar
Bent hinge pins? - 11.06.2005, 01:20 PM
I've got problem with bending titanium hinge pins. I'm using supermaxx titanium pins, but the front bottom hinge pins keep on bending at the back (near the steering bellcrank). I know why they're bending, its because when i turn at high speed the lower A arm transmits a lot of force to the bottom pin, and it bends.
What i want to know is are there any stronger pins (hardened steel, lunsford titanium etc...) and where can I get them from? cheers
ps. if you want a pic to see what I am talking about, just ask.
Papa
Papa's Avatar
11.06.2005, 01:24 PM
What suspensiona and bulks are you using? A pic would be nice.
maxxdude1234
11.06.2005, 01:41 PM
I'm using stock suspension, and greatassemblyrc bulks. I just took this pic, you can get an idea of what is going on. You can see the the 2 lower arms are angling in slightly by the steering assembly.
Sneeck
RC-Monster Custom
Sneeck's Avatar
11.06.2005, 02:37 PM
Try steel hingepin's. They are stronger than titanium.
Else upgrade your suspension to aluminum. Alum arm's won't worp like plastic one's do at tight corner's.
maxxdude1234
11.06.2005, 04:16 PM
Surely nylon will flex more than aluminium, hence taking the pressure off the hinge pins. Anyway, I don't feel upgrading to aluminium suspension is a worthwhile upgrade unless its racerx......and unfortunately i cant afford that yet.
Papa
Papa's Avatar
11.06.2005, 04:23 PM
Are your arms properly shimmed?
maxxdude1234
11.06.2005, 04:25 PM
Don't think so. Are you refering to the plastic spacers that alter the caster?
Would something like this be good?
http://www.rchobbies.net/index.php?m...oducts_id=4370
Papa
Papa's Avatar
11.06.2005, 04:31 PM
Link not working.
Yes, those are the shims I am speaking of. Some use the plastic spacers Others work with a few 3mm washer/shims. Their placement is used to adjust caster. Your arms ought not move forward or back on the hinge pin.
coolhandcountry
coolhandcountry's Avatar
11.06.2005, 06:47 PM
I have had good luck with the integy racer x suspension. I have not broke or bent nothing yet. It is a lot cheaper than the ue. I think by upgrading it may fix you problem.
Peace!
Country
Help support the
Rc-Monster
Buy here
maxxdude1234
11.06.2005, 07:34 PM
At the moment I have other things on my truck that really need changing. I need a new body, wheels and tires, and could do with some new shocks. Maybe integy type 3 will come after that. :D
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.06.2005, 07:44 PM
Here is another tip that you may be able to implement. If you can get a hingepin that is long enough, try putting a thin hinge pin brace on the back side(in front of the steering bellcranks at the rear of the front bulkhead). I was able to use the stock maxx steel skidplate brace(part that comes with the plastic skids) on one truck that was having similar problems. Even a thin piece of steel like this helps strengthen the hingepins behind the bulks. Even is you have to remove some material from the bulks to make it work(in front, for example), this may be a cheap trick that stops your troubles.
coolhandcountry
11.06.2005, 07:49 PM
Mike dude. that is like so simple. Yet brillant. Why couldn't I think of that? Oh yeah Have to think first. :D
Peace!
Country
Help support the
Rc-Monster
Buy here
Sylvester
Sylvester's Avatar
11.06.2005, 08:32 PM
Where did you get that CF skidplate? And how is it holding up so far?
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
squeeforever
squeeforever's Avatar
11.06.2005, 09:47 PM
i believe that is a xtreme racing low cg chassis. not positive but pretty sure. i think they eliminate the skids. most people run the rpm wear plates.
maxxdude1234
11.07.2005, 02:32 PM
right on squee. Got it for $130 off ebay, gonna get some RPM skids shortly - still havnt run the chassis yet
