Im quite perplexed..
brushlessboy16
brushlessboy16's Avatar
Im quite perplexed.. - 09.20.2008, 04:19 PM
Hey guys im having trouble diagnosing a problem with my truck
Setup is:
Warhead
1515 1y
MMM
5s zippy 4000mah lipo
I ran the truck for a little bit this morning, the batt was at 110degrees, the motor was at 125, relatively cool but the fan on the esc kept coming on, i dont get why... if it was overgeared the motor would be hot at would the battery, and if it was undergeared wouldnt the motor get hot?
only the MMM is hot.
brushlessboy16
Addon
geared for 45mph
theJoker
09.20.2008, 04:25 PM
did you verify that you do not have a rolling resistance problem
if that 45 including tire growth?
I have an eRevo 4s 8000ma TRC and 1y geared for about 40. It weighs 11.2lbs... No heat issues ...
Can you gear it down and see if the heating problem goes away?
brushlessboy16
09.20.2008, 04:36 PM
no binding
and yes that includes tire growth
brushlessboy16
09.20.2008, 04:54 PM
well no more testing for the day... 1515 just ate my transmission up :D
09.20.2008, 05:30 PM
The fan came on when I ran both the truggy and the buggy with those motors... Now with the mods the fan runs all the time :) I really wouldn't worry about it...
Takedown
WARNING: May become violent.
Takedown's Avatar
09.20.2008, 06:03 PM
Doesnt sound like a big deal to me. I say dont let it get to your head...
RIP- Tammy (9/14/08)
09.20.2008, 06:49 PM
Over geared = hot batts and esc.
Under geared = hot motor.
Baddly over geared = hot everything.
sikeston34m
sikeston34m's Avatar
09.20.2008, 08:25 PM
If the fan only comes on for a bit, then goes back off........on........off........on.........off
Then this means it is keeping up with the heat production inside the ESC. It is getting cool enough to satisfy the thermistor when the fan shuts off.
I'm curious about your transmission. What let go? The output gear?
09.20.2008, 08:50 PM
I think the "Duratrax" part in the tranny broke...
brushlessboy16
09.20.2008, 08:55 PM
must not pay that much attention linc, its and e-savage trans
Takedown
Takedown's Avatar
09.20.2008, 08:56 PM
It lasted quite a long time.
09.20.2008, 09:17 PM
That would be the problem, try the kershaw esavage upgrade gears. That is a weak tranny, btw...
brushlessboy16
09.20.2008, 09:21 PM
its stronger than i thought it would be but problemed will be solved shortly..
Cough truggy+
trev3813
Dsm needed
trev3813's Avatar
09.20.2008, 10:19 PM
Truggy? Now what do you have planned?
