Will savage slipper/spur fit?
truckbuilder06
Will savage slipper/spur fit? - 09.21.2008, 08:59 AM
Does anyone know of the savage 51t slipper/spur fit on the gorillamaxx g1 tranny. I know people are using the ofna spur, but will this work as well? Here is a pic of what i would like to use if it would work.
George16
Supermaxx
George16's Avatar
09.21.2008, 09:10 AM
If you are looking for a Mod 1 spur and slipper as an alternative to the Strobe, here's my suggestion:
RRP slipper:
http://www3.towerhobbies.com/cgi-bin...?&I=LXBJC8&P=7
MGT spur. Tower says it's 32 but it's actually a Mod1. I have one in my parts bin.
http://www3.towerhobbies.com/cgi-bin...?&I=LXFUA5&P=7
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
Getter Robo
RC Monster Fiberglass
Getter Robo's Avatar
09.21.2008, 03:32 PM
I'm using a Savage X spur (the ones with slipper plates on both sides) together with the sliper discs from the RRP slipper kit which i filed completely flat. Im using another stock slpper spring as the bushing.
Works pretty good and looks like this :)
The usual savage spurs work too, but you first have to put a stock slipper pad (or a smilar shim) before the RRP Pad (and then the spur) to make it work. But sadly the only option of slip adjustment with this method is "air tight"...
Tesla 4 president!
truckbuilder06
09.21.2008, 03:36 PM
Thanks guys for the info...
