Originally Posted by What's_nitro?
The motor on the right seems to use a slightly smaller radius for the screw pattern. I'm just eyeing it. If the motor on the left has a 25mm radius then the other appears to be less than 24mm. Does it have two different radii? 25mm and another? I'm sure Neu wouldn't mind replacing the endbell for you if need be.
yes there differant radi....I just drill another hole in the motor mount and it fits fine now
now the mmm wont calibrate...I have steering but no throttle...the fan is running and you can rev up the fan with the throttle trigger on the tx...lol
