First drive with MMM/Teckno Nue 1y
shizzon
shizzon's Avatar
First drive with MMM/Teckno Nue 1y - 10.14.2008, 12:26 AM
Finally got my pinion gears in today and went out on its maiden voyage, went to a grassy park a block away from my house and i have to say i am very impressed. The power is instantaineous, torque is awsome, and the MMM held up to all i put it through (high speed runs in grass and asphalt as well as a lot of hard acceleration). I have to say that pulling wheelies nearly any time i want is somethin else, and i can say that without this forumn this couldnt have happedened, and i thank you all for being so helpfull and informative.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
10.14.2008, 12:30 AM
Glad to hear it! Now, fix that sig.
shizzon
shizzon's Avatar
consider it done!
Toys:
Slash with VXL
Ryu James
Ryu James's Avatar
10.14.2008, 02:42 AM
sounds great. how fast would you say the revo will run now? can you throw some pics on? would love to see it.
Jammin SCRT10 Neu 1512 1y
shizzon
shizzon's Avatar
10.14.2008, 08:25 AM
ive got some pics of it nearly completed on one of my other threads, the only thing missing is the pinion gear. As of right now it is geared 22/58, and according to the speed calulater it is right around 45 mph, i havnt had the opportunity to play with the gearing much, but i also have the 24 tooth pinion and some other spurs.
Toys:
Slash with VXL
FullMetalGrave
FullMetalGrave's Avatar
10.14.2008, 10:00 AM
Keep us updated about that setup :) That is the same esc/motor/battery setup I am looking to put in my Maxx
shizzon
shizzon's Avatar
10.14.2008, 11:05 AM
will keep you guys posted. On a side note i tried to adjust the voltage cutoff to 12.4v, so 3.1 per cell and there was no throttle, steering worked but nothing happened except as i pulled the trigger the fan increased in rpm.? So i took it back to the auto-lipo and it works fine. Any ideas on what is wrong here?? I would just like to have a little more headroom on the batts to prevent over discharging.
Toys:
Slash with VXL
Chapito
10.14.2008, 01:49 PM
I have the same issue with my V1 MMM. I set it for 12.0v(pre-set) cutoff the second time and it worked fine. I read on one of the threads that with the most current firmware update the custom cuttoff works properly but with all the issues(deaths) and mine working so well, I've left it alone.
shizzon
shizzon's Avatar
10.14.2008, 02:31 PM
so downloading the new firmware might fix this? i guess its not necessary and im just happy that its working but i would like to change the voltage cutoff. anyone have any advise?
oh, and wish me luck, 254 vector calculus exam in 30 min!!
Toys:
Slash with VXL
shizzon
shizzon's Avatar
10.14.2008, 10:04 PM
ok, heres the one pick that i got from one of my bash sessions, It landed nearly vertical on the fin, and snapped the rear fin/shocktower mount. Oh, and the front wheel popped off as the nut was pulled through the wheel. not too bad for a good 40 ft distance and probably 20 feet of vertical!!!!!!!
I NEED PARTS!
Toys:
Slash with VXL
shizzon
shizzon's Avatar
10.14.2008, 10:13 PM
From New rc
Toys:
Slash with VXL
shizzon
shizzon's Avatar
10.14.2008, 10:14 PM
kinda dark, we pulled the camera out a little too late.
Toys:
Slash with VXL
10.14.2008, 10:45 PM
Nice air! :)
Ryu James
Ryu James's Avatar
10.14.2008, 11:41 PM
revo looks bad. what is that little red and black gadget around your MMM that looks to be holding it down?
shizzon
shizzon's Avatar
10.14.2008, 11:45 PM
Its my homemade mount that i built from the traxxas esc mount, piano wire and a o-ring. it is actually really sturdy, i can pick up the whole truck with batts and all by the speed control no problem....its not going anywhere!!!
Toys:
Slash with VXL
