Problem programming 9920 -
11.20.2005, 06:15 AM
Hello,
I finally got my savage build up and got the warrior 9920 with the 7XL motor.
I'm trying to program it but I can't do it so far. I tried the way of Mike, the way of the instruction guide from BK, but that doesn't work. I only hear one beeb and when I hit full throttle, I don't hear anything anymore.
But it does work when i
1. connect the motor wires
2. plug in the wire from the warrior in the receiver.
3. plug in the drive cells
4. Put on the transmitter
Then I hear one BEEP, then I hit full throttle, and then I hear two BEEPS. I thought that the controller is then programmed succesfully. But when I put on the red jumper en connect all the wires. The motor is driving full throttle backwards. And then I can't get the red jumper off the esc because I think this isn't right.
Can someone helpe me pleaseeeee
I WANT TO DRIVE THIS BEAST!!!
