my muggy 8s
masense
my muggy 8s - 11.16.2008, 02:16 AM
muggy monster!!
big pig! fast! I like this.
mgm 16024
1521 1900kv
11/46 (esc hot! 10/46 I am going to change it)
8s 4000
bdebde
That's All Folks!
bdebde's Avatar
11.16.2008, 02:55 AM
nice, you may need a bigger esc with that motor.
Finnster
KillaHurtz
Finnster's Avatar
11.16.2008, 09:29 AM
Wow, that's a huge amt of power. Do you know how many amps you are pulling? Perhaps that's a bit much motor (high kv) if you are getting it that controller hot. The MGMs are very tough. I can tell you if you tried to make that much power with 4,5, or 6S you would have a flaming wreckage by now. You may need to go higher voltage even if the temps are not controllable (or gear down to lose power)
Thats kinda what I was thinking of doing w/ the muggy roller I have, as well as the MGM 9932 esc I have as well. Perhaps on 10s and lower kvs tho.
Nice truck tho. About 5000x faster than the nitro w/ the 427 engine in it.
11.16.2008, 11:10 AM
Nice. You need to get a lower kv motor though.
masense
11.16.2008, 04:44 PM
my 6s muggy move!
8s may be surely bad in ESC.
A motor of low KV that I expect it.
There is not a fund now because I bought RC8 and a TEKNO set.
I can be satisfied very much even for 6s, but cannot come back if after all I feel 8s.
OK, I will do it how…Because a price is too high, does NEU have a recommended motor?
I wait for Medusa Products Afterburner 80size.
11.16.2008, 04:53 PM
6s looks like fun, more controllable.
Finnster
KillaHurtz
Finnster's Avatar
11.17.2008, 12:27 AM
What are the temps? Are you getting shut downs?
Getting a 80mm Medusa will not help. Its basically the same motor as a 1521.
You are spinning that motor very very fast. Beyond what is recommended. Lots of power, but lots of heat as a result as well. How many amps are you pulling, and what are the temps of the motor and esc?
Getting a lower kv motor and gearing up may be a better way to go than gearing down that setup.
masense
11.17.2008, 02:25 AM
MAX amps 370A of ESC.
Is it continuation ??
The power does not fall. slow down.
MAX TEMP 100 ℃full throttle around 4 minutes.
Motor 65 ℃-70℃
I change pinion 10T of it first of all.
And I change it because the tire bat land is heavy.
masense
11.27.2008, 04:23 AM
new vid!
is 6s...
speedy
11.27.2008, 04:50 AM
How mutch trottle did you use in your vids ? Your muggy seems kind of slow ? But still cool :)
dirt101
dirt101's Avatar
11.27.2008, 09:33 AM
wow that thing is FAST even on 6s...8s is just over the top.
rustler, lx2e, xxt cr
masense
11.27.2008, 09:45 AM
6s 70%~100% trottle
8s 50%~70% trottle
6s very good!
8s When stress piles up!
11.27.2008, 11:47 AM
Looks like the sweet spot is 6s.
