problem cogging with neu and xcelorin
Blade98000
problem cogging with neu and xcelorin - 11.21.2008, 04:07 AM
hy,
i have a eight buggy with the losi brushless kit with the new xcelorin controless and neu 1515/2d/f
i use a zippy 4s 5000mA and a 15 pinion
i have a problem : there is a little cogging when i push a little the throttle
here are my settings
where is the problem
sorry for my english but i m french ...
thx so much for the future answers .
Maciolus
11.21.2008, 04:12 AM
As far as i know four pole motors like higher timing, like 10%
> HB L2PE + MMM + Medusa 60-1600 @ 6S A123
> HB LSP + MMM + Medusa 70-1600 @ 6S2P A123
> AE B44 + MM + Medusa 50-3300 @ 4S A123
> AE J82 + SW 5700 @ 2S LiPo
> AE TC5R + MM 6900 @ 2S LiPo
11.21.2008, 06:38 AM
change timing from low to med. or high, but be sure to check temps closely after changes
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
11.21.2008, 06:46 AM
I thought D-Wind motors run better on low timing. Have you tried Initial Acceleration on a lower setting?
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
11.21.2008, 07:03 AM
4 pole motors in general like higher timing
Blade98000
11.21.2008, 07:07 AM
I will try lower initial acceleration and if the results are bad i will try higher timimg but someone told me that D prefers the lowest timimg
thx for the answers
Blade98000
11.22.2008, 10:15 AM
anybody else use neu and xcelorin ?
11.22.2008, 11:15 AM
please post after you change settings, as I want to learn from you! I believe lowering accel. will make it cog worse, but I think higher timing will help, and I've never heard of the wind making a difference but I know every 4 pole setup I've seen had atleast med. timing, the schulze 18.97 comes set to high timing to match the 4 pole big maxximum
Edumakated
11.22.2008, 12:37 PM
Neu says to run their D winds with the lowest timing and higher timing with the Y winds.
11.22.2008, 12:40 PM
I guess higher timing is still worth a shot though. Try med and see where it gets you. How much cogging are you experiencing? A little bit is normal and can't really be avoided with some higher-pole motors.
Blade98000
11.25.2008, 04:46 AM
ok thx
I will try to set acceleration and timing to lowest and test
then let the acceleration to low and test medium timing and test
I will update my results here
thanks for all
DRIFT_BUGGY
11.25.2008, 05:20 PM
Sweet, let is know the outcome
Losi 8ight
MMM V1 w/1.20
TP 5S 5000mah
Neu 2.5D/F
bdebde
That's All Folks!
bdebde's Avatar
11.25.2008, 06:41 PM
Check all the connections well, a poor connection can cause cogging. I also found that poor batteries can cause it too. I have seen with my lehner motors, that low timing and low start power can cause a little cogging at low throttle. I run all my Lehners at 15 degree timing and high start power. Neus I have had no problems with timing, but start power can make a difference.
