2 questions about the V2 RCM diffs...
Nautilus
2 questions about the V2 RCM diffs... - 12.05.2008, 02:17 PM
1. Can I use the stock revo axles (6mm?) with the outdrives on the diff (also 6mm? or 8mm?)?
2. If I use a dogbone center drive shaft, can I use a 6mm drive cup on the tranny and an 8mm drive cup on the diff at the same time? Will the dogbone fit into both drive cups?
Thanks.
