Ok guys I talked it over with brianG and hopefully the thread wont get deleted this time.
I will be testing some motors coming up soon. As I had said before. Here are the specs, notice somethings have been changed.
Specs
Size- 44mm x 73mm
KV Rating- 1500 to 2100.
Poles- HQ 2-pole
Internal Resistance- To be determined...
Features
Kevlar wrapped rotor, rotor will be reinforced with dual supports on lower and upper shaft, shimmed rotor, 100k rpm ceramic bearings, finished bonded rotor, 12awg low resistance wires, 5.5mm plugs, motor will be all jet black color including black wires, will be finned can, HQ 2-pole design, removable rear endbell, will be rebuildable, high strength neodymium rotor with a rating of n38-n45, high quality windings which offer super low resistance.
The company has shipped out the cans and endbells along with the shaft. We are still looking to order the neodymium magnet and outer can magnets along with the windings and high quality bearings. Once some of the stuff arrives, I will post pics threwout the motor's build.
