Need Some Advice!!!
satan'struck
satansbackyard666
satan'struck's Avatar
Need Some Advice!!! - 01.17.2009, 06:09 AM
Guys, just wondering if anyone of you ever own a RC4WD Crawler??? Cause I'm kind of want to get this 1/5 Large Scale Killer Krawler Kit for US$799.00 from RC4WD, any word??? THX!
ID:	6248   Click image for larger version
ID:	6249   Click image for larger version
Killer stuff.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Killer stuff. - 01.17.2009, 06:26 AM
That kit looks pretty good from what we can see in the photos. I guess we cold go and look it up on their site and check it out closer. From what I know of RC4WD they do ok. I have several sets of their EMaxx tranny gears & I have gotten a few other things from them without issue. I think from what I can tell they are a lot like RCM in that they do some custom work in their own shop, and piece out work to a local machine shop much like Fastlane. WIthout actually working with that kit is is hard to tell what you are getting as far as quality goes. I wouldn't mind getting one, but $800 is a lot of money right now for anyone to spend on toys. Then you also have to fill it with electronics and such which will be even more money to spend. If you do acquire this kit please come back and share your opinion with us here on RCM. It could be interesting to hear about for sure. Good luck with that.
thx
satan'struck
satansbackyard666
thx - 01.17.2009, 11:18 AM
thx for the info JERRY2KONE
TexasSP
Something, anything, nothing
TexasSP's Avatar
01.17.2009, 01:23 PM
I would post this question on rccrawler.com as you will probably get more feedback.
www.cubicle101.com
01.17.2009, 02:12 PM
It is based on a clod - you could get a g-made for much less...
rabosi
01.18.2009, 02:07 PM
That one peaked my interest as well. I did some checking on the forums, but at the time could not find anyone who had one. It's quite a bit bigger that the G-Made stealth judging by the dimensions (almost 6 inches on wheelbase). As mentioned above it'll be over $1000 to finish it.
chip cross
01.18.2009, 05:17 PM
It is bigger then a G made Stealth but is still a motor on axle or MOA just like the Clod, Stealth, Berg, or Hot Racing MOA axles for the AX-10.
satan'struck
satansbackyard666
01.19.2009, 04:50 AM
hi guys, the junfac stealth is a good crawler but since i already got the spider with 2 spare chassis(stealth & g1) i think i'll try to get something else...and the main reason is that the junfac gearbox is knid of weak...but the rest of the crawler is pretty good, wasn't bad for that price!!!
Serum
Serum's Avatar
01.19.2009, 05:45 AM
Looks pretty neat, does it come with metric hardware and is it machined or moulded?
are the gears etc included?
01.19.2009, 11:04 AM
From what I can gather everything is included. I am sure the cases are case, then machined where necessary. Definately a big truck, with a 22"+ wheelbase. Most super class rigs are 17" maxx for the wheelbase. I am working on a clod axle based truck and those axles mook similar, but better designed. The motor is higher up so ground clearance, especially at the back should be much better. MOA (motor on axle) trucks are better in most respects than shaftys, as the weight is lower and the lack of driveshafts opens up different chassis and linkage opportunities.
satan'struck
satansbackyard666
01.20.2009, 12:22 AM
thx alot lincpimp!!! that's really helpful info that you gave menow the only is that i've to find a way to get the crawler without letting my WIFE A CHANCE to yell at meif you know what i mean
Thats easy.
JERRY2KONE
JERRY2KONE's Avatar
Thats easy. - 01.20.2009, 02:07 AM
there are several methods that you can use. 1) buy her something nice as cover for what you really spend your money on. 2) make the purchase and tell her that it is an early Birthday present. 3) put your foot down and tell her who is boss.
01.20.2009, 02:40 AM
4) do it behind her back, then claim ignorance. This works with more than just rc!!!
TDC57
TDC57's Avatar
01.20.2009, 04:16 AM
Don’t do the third one!..
I do what Linc does: whistle:.. do it behind her back, then claim ignorance. This works with more than just rc too...
Nothing!.. Hahahahaaa..
satan'struck
satansbackyard666
01.20.2009, 11:32 PM
guys, i'll say NONE OF THE ABOVE WILL EVER WORK FOR MEsince i got a 1 year old little girl and most of my $$$ belongs to her now.....
