FYI: 36-80-1600 Weighs almost the same as a CC2200
Raze ST Truggy
FYI: 36-80-1600 Weighs almost the same as a CC2200 - 02.11.2009, 12:51 AM
I recieved my Medusa 80mm 1600kv motor yesterday. The first thing I did was take it out of the box an weight it. The medusa came in at 403g while the CC2200 that I have came in at ~421 I should note that that CC motor has longer motor leads and 6.5 bullets on it. That may be the difference right there.
Thought I'd through that out there incase any one was interested.
-Brian
Metallover
RC-Monster Spudgunner
Metallover's Avatar
02.11.2009, 09:10 AM
The Medusa motor probably has tighter, better quality windings.
02.11.2009, 10:45 AM
Given similar design, motor weight is often a good indication of power output. The castle motor is larger in diameter, and has a finned can. Both add weight. IIRC the ccneu has a larger diameter magnet assy, so that will be heavier and produce more torque. I would be interested to see the magnet assemblies compared, but how do you get the endbell off a medusa?
bruce750i
bruce750i's Avatar
02.11.2009, 10:53 AM
I think you would hit the shaft on the end, to drive the endbell off. I have a 60mm end bell slipping out every now and then. Looks like its just friction holding it in.
02.11.2009, 11:21 AM
Good to know, I figured that it was just pressed in...
And who is the dude in your avatar?
bruce750i
bruce750i's Avatar
02.11.2009, 11:46 AM
Hey Linc: "Are you talking to me?" That is Robert DeNiro in the movie "Taxi Driver".
02.11.2009, 12:05 PM
Damn he looks young in that pic... Skinny(er) too!
