First Drive: RCM 5s Lipos
shizzon
shizzon's Avatar
First Drive: RCM 5s Lipos - 02.26.2009, 07:10 PM
Ive had these packs for a week or so but just got my motor back from Neu today, needless to say I was excited to see that little white box on my porch when i got home from school.
After getting the motor soldered up and checking everything over i went out and gave the packs their first run. Setup is and E-Revo with MMM/teckno Neu 1515/1y, and the truck was geared 22/65 which is right about 45 mph. ambient temp was right around 32 degrees F and initial pack temp was 65.
These packs have punch!!!! without warming the packs up i put them in the E-revo and noticed a big improvement in overal power when compared to my 4s setup that i have been running for a while. Wheelies at nearly ANY speed, top speed was impressive but i tried to limit going that fast as my badlands stated to look like dinner plates. the truck easily and accidentally backflipped off a small jump!!! On another good Note the new MIP cvd's and Hitek 7995 servo worked flawless as well! i did not get to run these packs to LVC, and i will see how many mAH were used during the 15-20 mins i was messing around.
Temps:
Motor: would not got above: 112
ESC: fan rarely came on and if it did it shut off in a few seconds
Batteries: at the end of the run: 85
Now to the bad: pretty sure that both my diffs are on their way out as they are getting rather noisy and i broke the front center driveshaft.
All in all Ide say that these packs are excellent, and i will continue to report on there performance.
Toys:
Slash with VXL
E-revo with MMM/Teckno Nue 1515/1yf running 4s and 5s
