emaxx wheelie from stadstill? -
12.27.2005, 08:22 PM
I heard a stock emaxx will wheelie from stop. My new emaxx has full cvd's and a 64 tooth spur gear. now although i don't think i've gunned full from a stopped posistion ( trying to break it in somewhat) i don't see the front wheels wanting to lift off the ground (on pavement). is this because i put in the 64 tooth spur?. Thanks.
I tightened the slipper down all the way and turned it a 1/4 turn back per the insturctions. is that too much? should i run this thing with the slipper full tight?
Originally posted by maximum I tightened the slipper down all the way and turned it a 1/4 turn back per the insturctions. is that too much? should i run this thing with the slipper full tight?
I didn't loosen any, i tightened as tight as i could and left it
