what connector size
BL-revo
what connector size - 03.06.2009, 04:15 PM
hi guys
i need a bit of advice. i have some 5.5mm and 4mm bullet connectors along with some fake deans but which is best for a mamba max with 4s lipos and a 2000kv motor? i can get a hold of some 8mm and 6mm connectors but will they offer better performance ?
should i use 4mm with batteries and 5.5mm with the motor? also are fake deans any good or will they not cope with the current draw?
thanks richard
03.06.2009, 04:29 PM
I'd go deans for battery as like having polarized connections...
If it is a medusa motor the wires are pretty small so 4mm is probably ok - personally I swapped all of my motor connections now to 5,5mm. If starting out from scratch I'd go there.
Another Limey
BL-revo
03.06.2009, 06:03 PM
Another Limey
does it matter that they are fake deans like these:
http://cgi.ebay.co.uk/BEST-Deans-typ...1%7C240%3A1318
will i see any difference between those and 4mm bullet connectors? and i am careful with the right polarity now after blowing 3 speedos in 1 day once
