04.07.2009, 10:34 PM
So you can use a revo spur and it will connect with a pinion, not worried about gearing, i can get that. thanks, just wanted to know.
My current setup is using a 3096 Emaxx tranny w/gorillamaxx half tranny conversion and a strobe/51 mod-1 gearwith 20 tooth pinion, motor is a 1515/2.5d/f (1700kv) neu on 5s.
here is BrianG's calc of it
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1.7222222222222223
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 20
Total Voltage: 18.5
Motor KV: 1650
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.01
Spur/Pinion Ratio: 2.55 : 1
Total Ratio: 14.52628 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 30525 RPM
Vehicle Speed: 36.26 mph (58.24 km/h)
here is same pinion using E-mexx/revo (3095) with 40 (revo Mod-1) tooth spur
Transmission Ratio: 1.8333333333333333
Other Ratio: 1
Spur Tooth Count: 40
Total Voltage: 18.5
Motor KV: 1650
Motor coil Ω: 0.01
Spur/Pinion Ratio: 2 : 1
Total Ratio: 12.12821 : 1
Vehicle Speed: 43.43 mph (69.76 km/h)
only 7 MPH difference, so i'll be close. thanks for the info.
if it becomes an issue of power, i can drop a 2250/10t in it, that'll pull any gear i want
