MMM failure
reddyteam
Natty Red all day
MMM failure - 06.23.2009, 05:58 PM
I install a new mmm esc in my truggy,when I plugged in the battery I got no response from the esc.(no sound,no lights) The steering servo works
"Natty Dread inna Babylon"
06.23.2009, 06:00 PM
Did you bind the esc to your radio?
reddyteam
Natty Red all day
06.23.2009, 06:06 PM
Yea,I binded it.
brushlessboy16
brushlessboy16's Avatar
06.23.2009, 08:00 PM
bound..
Did you calibrate the esc?
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
06.23.2009, 08:22 PM
No lights?... Does the fan go crazy-fast? Usually that means you need to bind the ESC. If you did that already then I'm out of ideas. The lack of lights is interesting. Almost sounds like your Rx is fried. IS the ESC plugged into the Rx the right way?
joeling
joeling's Avatar
06.24.2009, 02:48 AM
Switch
Hyper 9e Medusa 4S, Savage 5S MMM 8XL, Jammin' 4S Neu MMM, X2 Ninja JX, X2 MMM 5S Neu, E REVO Medusa 6S
Thomas Porfert
Thomas Porfert's Avatar
06.24.2009, 01:21 PM
Hmm very strange. You are using the stock on board BEC correct?
If you are getting steering then the radio should be bound and the switch is working. If it isn't calibrated the lights should still come on. It doesn't even have to be plugged into a receiver to get the lights and the initialization and Auto-LiPo tones.
There is a remote possibility it is the throttle channel on the receiver. Switch the speed control to the steering channel and the servo to the throttle channel. Power the speed control on as normal and try the throttle trigger. If the servo doesn't work, you have a problem with the radio. If the steering does work, that eliminates the radio.
If you verify the radio works, I think the next best option is the Castle Link. Hook it up and click on the software tab; select firmware version 1.21 (beta) and click the Update firmware button. After the update, hook it back up to the truck and try again. Sometimes flashing the processor can fix strange problems like this. If this still doesn't work then give us a call in Tech Support, we may have a bad Monster; and it will need to be punished for being bad.
Let us know how the testing works and we'll get this sorted out and get you up and running.
