Ease of turning by hand 36-60-2000?
Raze ST Truggy
Ease of turning by hand 36-60-2000? - 06.27.2009, 08:21 AM
I just sold my converted Raze buggy with a V2 36-60-2000 and just recieve a V2 36-60-2000 that I bought used. One was significantly easier to turnover by hand than the other. Does this sugest that the one easier to turn by hand may have a problem? weak magnet (demagged)?
I'm going to test it out in my rustler and see if I can tell a difference. I was just hoping that someone here might have some insight for me. Thanks
-Brian
06.27.2009, 07:45 PM
The used one is easier to turn by hand correct? May be partially de-magged yeah. It will cog more from start up, and temps will climb much quicker during use if thats the case..
Raze ST Truggy
06.28.2009, 09:30 AM
Yes it is the used one that is easier to turn. Do you think I should run it or just send it to medusa for a checkup/ repair? The more I think about it, I already know the answer to that question.
Thanks for the answer Neil.
-Brian
06.29.2009, 02:35 PM
Send it in
Raze ST Truggy
06.29.2009, 07:26 PM
Send it in
Yeah, I'll have it in the mail by the end of the week.
I just gave it a quick run and it deffinatly has some issues. I've never had a motor cog, but I think thats what this one does. It's not from a stop, but at low speed it seems like it's cogging pretty bad. Once it gets past lets call it 3-7mph it's fine, but something is definatly wrong.
Does anyone know if medusa has a flat fix rate for motors like castle does?
-Brian
himalaya
himalaya's Avatar
06.30.2009, 01:36 AM
Short the three leads together and turn the shaft, (now it's a electricity generator)if it's still easy to get it spin, it's de-magged, send it in for rotor replacement.
....What a Blue Sky....
07.01.2009, 12:56 AM
-Brian
Medusa fixes them for free. At least they did when I snapped my shaft on the 36-70....
scarletboa
scarletboa's Avatar
07.06.2009, 03:34 AM
that's what i did with my VXL motor after noticing that it practically free-spins when turned. surprisingly, it was only veeery slightly de-magged. now it runs as hot as my EZrun 3300kv motor.(i think the dent in the motor may have a role in that too)
