Is This Bind
bigabike
Is This Bind - 01.31.2006, 11:58 PM
Hey Guys,
I am trying to rule out reasons my 9920 got so hot. I made a short video to see if my truck is binding or not. If you have time, please take a look and tell me what you think.
Thanks!
http://www.rustyonline.net/bindMovie.wmv
Scott711
Scott711's Avatar
02.01.2006, 12:26 AM
Did you disconect the motor from the driveline? You need to do that to test for cogging. You could just pull the pinion off. If you have then I would say you have some cogging or something dragging your tranny. I just did a test similar to yours with mine and it free wheels very fast with the pinion removed but goes about the same as your with the pinion still attached.
bigabike
02.01.2006, 12:34 AM
I removed the controller Motor and Batteries.
It got hot with stock diffs. I upgraded with FLM cups etc. I did the single speed gmaxx conversion, but it seems smooth.
I am going to put some weight back on the truck and test it again.
Thanks!
Scott711
Scott711's Avatar
02.01.2006, 12:41 AM
With the motor disconntected from the driveline the truck should roll freely just like a kids tonka truck. :cool:
stampy
stampy's Avatar
02.01.2006, 05:13 AM
it looks like theres no motor in it in the vid. my guess is i dont think the problem is binding cause the truck rolls evenly my thinking on binding is if your truck rolls smooth a few inches then binds and almost stops then rolls freely again. spin one wheel and see how long it spins if all the wheels spin nicely then the problem is in eather your drive shafts coming off the tranny the tranny it self or the ring gear and pinion gear. hope that helps :)
Dafni
Dafni's Avatar
02.01.2006, 08:03 AM
Interesting vid. Nice idea, made me smile!
I think you have some binding there. If I do the same with mine, they roll better!
I always keep an eye on my drive line. Your best bet is to test every area individually with your fingers. Sometimes the diffs need a bit of break-in (you could do this with a drill)
In your case it might even be only one single bearing somewhere. Knuckle-bearings like to die from time to time.
Good Luck!
Batfish
Batfish's Avatar
02.01.2006, 09:56 AM
Based on your video, I'd have to say you've got some binding somewhere. That truck should have rolled down the first incline at least as fast as it rolled down when you held the board up high later in the video.
Definitely check the bearings in the truck.
I'm not too familiar with the Savage, but I do know that some vehicles don't like the wheel nuts tightened down too far. For instance, if I tighten down the wheel nuts on my T4 too far it will actually compress the parts on the axle into the bearings and stop the wheels from spinning freely. What I'll usually do is tighten snugly, then back off about 1/4 turn, making sure that the nylock part of the nut is still firmly engaged. Again, I'm not sure if this is applicable to the Savage, but it's another thing worth checking.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
coolhandcountry
coolhandcountry's Avatar
02.01.2006, 10:13 AM
I can set my truck on the hood of a car and they will roll off with the motor intact. Just for reference.
Peace!
Country
Help support the
Rc-Monster
Buy here
crazyjr
crazyjr's Avatar
02.01.2006, 10:22 AM
My G2R rolls better than that with no motors, so i think you have some drag issues. I would disassemble everything and double check everything
bigabike
02.01.2006, 01:31 PM
Wow, thanks everyone!
I made the video because I could not think of a better way to describe it.
I am definitely going to try the drill idea on the new diffs. They are pretty smooth, but I am sure it wouldn't hurt.
The $64 question...
Is the amount of bind I have enough to cook my 9920?
Thanks again guys - I learn so much from all of you! I really appreciate it!
Dafni
Dafni's Avatar
02.01.2006, 01:46 PM
Well, binding in the drive-line is the same for your BL combo as too tall a gearing.
If it's enough to fry an ESC is another question. Could well be, though.
I once got a pebble into the chain-drive of my TF, pushed the throttle only for a second, and the ESC thermaled. Afterwards BK told me I had a 130 amp peak on it. (seemed strange to me, was only running a 9L on 14 cells)
Serum
Serum's Avatar
02.01.2006, 01:53 PM
Sorry for missing this thread;
What gearing do you use? and what diffs? and what motor?
bigabike
02.01.2006, 01:56 PM
No problem.
18/66
FLM Cups and gears with stock enclosure.
8xl
12 cells
