Go Back   RC-Monster Forums > Support Forums > General Nitro
Possible bl conversion on rc10gt (old chassis)
Thunderbruiser
Thunderbruiser's Avatar
Possible bl conversion on rc10gt (old chassis) - 02.01.2006, 08:08 PM
well i won an old rc10gt on ebay for $61 it was arr only need radio...or so i thought....lol the motor doesn't run and the tank had a major leak in it so i stripped it and am planning on a bl conversion lol i was wondering if the feigao
Model: FG540L 3072KVM would be a good choice for the conversion
here are the stats:
Brand New, Never Mounted, in manufacturer's box
1 Motor
UHT (Ultra-High Temperature) Neodym Magnets
Balanced Rotor
Ball Bearings
Magnet Rotor Length 30mm
Shaft: 3.2 mm x 16 mm, flat spot for seating pinion
Weight: 285 gr (10.8 oz)
Dimensions (Diam/Length): 35.8mm x 60 mm
Internal Resistance: 0.0076 Ohms
Max Amps: 77
3072 RPM/V
8 turns
Up to 50,000 RPM
Up to 16 cells
and run it with the mgm compro or something with a maxamps 2S2P 6000mah 7.4V Lipoly Pack...
Caster Racing Team 09'
Sik Wit It Racing Crew Fo life
garage:
E-CRT.5 brushed for now 13x2 orion(tekin g20)2s 5200mah lipo
  Send a message via Yahoo to Thunderbruiser Send a message via AIM to Thunderbruiser
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
02.01.2006, 08:18 PM
Might want to run a little more voltage through that motor, I'm guessing thats its a 8L w/ 1/8th shaft or so, due to the specifications. A novak brushless would give you better speed on 6 cells, and since it's a 1/10th truck I would opt for motor with 4200-5300kv or so if you're running 6-7 cells. The lehner basic's are perfect for this application, and the feigao 380c L versions would work too. The L 540 motors are just too big, as the S would be more ideal.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Thunderbruiser
02.01.2006, 10:11 PM
oh ok cool....i guess i could up the battery count to a say 11.1 volt but i wanna keep everything on the chassis...but thanks for your imput
garage:
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
02.01.2006, 11:45 PM
Even if you up the voltage with lipo, you still want to use a 540s motor or smaller even, since the 540L motors are made for heavier and bigger viechles and won't perform very well in a rc10gt.
Thunderbruiser
02.02.2006, 04:19 PM
will the 6 or 8s be better for my conversion?
garage:
boss 302
02.02.2006, 06:39 PM
an 8s would give you better runtime than th 6s
Thunderbruiser
02.02.2006, 08:21 PM
cool is the 6s faster than the 8s and also is it basically 6 turns vs 8 turn?
garage:
boss 302
02.02.2006, 08:34 PM
the 6s is faster but u will get better runtime with the 8s
squeeforever
squeeforever's Avatar
02.02.2006, 09:17 PM
i would look at something like the novak 4.5 or 5.5gtb.
Thunderbruiser
02.03.2006, 12:15 AM
really? but i wanna run it high power though...i mean the novak is cool but i'd rather run higher end stuff...plus the novaks can't handle li-po's right? and as far as run time it's not major unless of course we're talking 25 min compared to three min then i'd opt for 8s
garage:
