Mini E-revo 1/16 MM 5700kv Build/Review -
08.11.2009, 12:51 PM
Guys, I post on a few other forums so I just copied and pasted from my other threads. I posted my build on here with a Neu 1112 and couldnt help but try the 540 conversion. Anyways, here are my thoughts. Pics will come tonight when I get off work:
TENBOL MOUNT - I give this mount a thumbs up. It's pretty light and nicely machined. The customer service there is great. I installed it last week and ran into a problem where the mount would rub against my 55t spur. Shot them an email and they machined me one and sent it to me the next day! That's great service! So now I have an updated version of the mount that allows larger spurs. My gripes: the motor sits high with a lot of space under. This maybe so there is space to mount the ESC or receiver without hitting the side of the can. It would be nice if it could have been a few mm lower as the COG is raised considerably. Another thing is mounting holes. It would be nice if there was some mounting holes for 380 motors. I know this is for a 540 motor, but what about us that want to use a Neu 11xx or some other 380 with a longer can? Maybe something to think about Tenbol. You also have to raise your body posts to get the body to fit nicely. Either way good job and nice mount!
540 MOTOR: I picked the MM and 5700kv combo. For those that follow my threads on the other forums, I bought the MM used from a guy that said "practically brand new" and the thing came in beat-up and dirty. Anyways, I'm hoping there's nothing wrong with it. I upgraded the firmware to the latest one so it seems to be working fine. The 5700kv is used too but looks to be running good. For 2s I had about a 20min run before I got tired and stopped. I reached 105 on the motor and 115 on the ESC. NOT BAD! My setup weighs a little over 3lbs on 2s and almost 3.3lbs on 3s. With this weight the conversion pushed the mini around pretty well with minimal heat. I have it geared at 55/31 so it wasnt a speed demon at 2s.
My mini feels like a brick when I have both 3s in. This was my 1st run with the conversion and I was not impressed. With this setup I should have been geared at around 73mph. Sure didnt feel like it. After about 10 minutes of running I called it quits. Good thing. I temped both ESC and motor at 160+. WHY? I dont get it. I got this setup so everything would run cool with monster torque when I needed it. It was definitely hotter than I expected. And it sure didnt seem much faster than the Neu 1112 I had before this 540 conversion. Impressive? Not really. My Neu 1112 felt a lot faster. One thing I did notice was that the 5700kv didnt have the cog resistance when I turned the shaft, compared to the Neu which the cog from the magnets were so strong I could barely turn the shaft. This is a good thing. I freewheeled easily and it was easy to control on jumps. BUT the jumps were not nice. Bottomed out every single time and it does not sound healthy... especially for a mini that weighs 3+ pounds. At least I managed not to flip the mini over once. But the reason to that you'll read about below.
CONCLUSION - I'm a little disappointed. The power isnt much of a difference over my Neu 1112 380-size motor. The extra weight I definitely do not welcom. Not to knock Tenbol. Their mount is great. But for those with Neu 11xx already, it's really not worth it to go 540. My 2 cents. For speed runs this is cool. This is your perfect setup. But for bashing and racing I'd stick with a 380 size motor. There's a lot of weight and suspension sag with the 540 motor on there. The MM and a 380 motor seem to be the right balance for power and ability to fine tune. It might be a different story if it would run cooler on 3s. OH, not to mention MAJOR COGGING! This was cogging bad. I cant believe how bad the cogging is. It's horrible. I'm picking up a new MM and 5700kv combo just incase the ones I have are defective.
ADDITIONAL INFO - I am running Hyperion G3 VX lipos. 2s 1800mah and 3s 1600mah both ran in parallel. YOU CANNOT JUST RUN 1 PACK. You must have 2 packs in parallel as the amp draw is way up there. My 1st run my battery got hot! Was a lot better when I used 2 in parallel.
I also forgot to mention I have a center diff and a wheel/tire combo that makes my mini 2 inches wider than stock. That's probably the only reason why I didnt flip it over on the turns. That's also the reason I wasnt doung backflips and wheelies. The CD pretty much eliminated it, not to mention my NewEra wheelie bar.
That's my 2 cents. I'd like to hear some feedback from other people that have theirs setup as well.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.11.2009, 01:16 PM
I don't own a Neu but having heard so many good reviews on them, I tot that perhaps Neu was your best bet. Using the 540 motor means more weight and lesser run time and maybe more damage when u crash. Have you tot of cutting holes in the body shell for improved air flow?
Try a smaller pinion for the cogging. Because the stock motor is a 4000 kv motor and the MM a 5700kv motor, drop a couple of teeth on the pinion if you want a cooler motor. It really sounds like the gear ratio between the pinion and spur is way too low.
08.11.2009, 01:20 PM
At this point I do like My Neu setup better. I still have a bunch of testing to be done on this 540 conversion before I actually come to a conclusion on which setup works best for me. It just didnt make sense though. I was gettin temps that were 20f cooler with the 380 motor than the 540 motor. It's a little odd as you would think the 540 would be a run a lot cooler. I may have an issue with my ESC or motor. I bought them used and I now I hadnt. I'm going to sacrifice beer and drinks this weekend so I can buy a new MM 5700kv combo and see how that works out.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.11.2009, 01:28 PM
Hmm, if geared to the same speed, and both motors having the same efficiency, the 540 motor should be running cooler. Were you using the stock pinion on the 540?
The 540 could be partially demagnetised. And for all I know, Neu motors have very high efficiency. This may explain y you have a cooler 380 motor. MM motors are pretty average motors and so maybe it isn't fair to compare them to the Neus. If I were you, I will get a new 540 sized Neu motor and forgo the MM combo.
08.11.2009, 02:01 PM
True. The main reason I wanted to try this out was the fact I needed the MM. The 65a Quark I had on was good, but just not as tunable as the MM. Coming from a ERBE I completely forgot that these smaller cans arent made by Neu.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.11.2009, 11:00 PM
This thread is useless without pictures
RC-Monster Spudgunner
08.11.2009, 11:31 PM
Yeah, that's what I was thinking. I saw this thread, scrolled down, and said WTF?
But I'm looking forward to the pics!
08.11.2009, 11:40 PM
Serious? You guys never seen the Tenbol mount and a MM ESC before?
Here's a top view:
Stock rims on the right... the left is the extended wheel/tire combo that adds about 2 inches to the width. I dont have the mini until I get home
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.11.2009, 11:52 PM
Ok.. Make sure to hold it when you take the pictures.
08.12.2009, 12:16 AM
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.12.2009, 01:23 AM
From my experience, I'd suspect the motor before the ESC. Do you have another ESC or motor to swap out to determine which is the culprit?
Another factor may be that the batteries cannot properly handle the current the motor requires. It's just a thought, I know the 5700 can be quite an amp hog on 3s.
08.12.2009, 01:28 AM
Just swapped the 5700kv with my Neu 1112. Same thing.Major cogging. The lipos are Hyperion G3 VX 3s 1600mah 35c cont. With 2 in parallel it should be good for 112a correct?
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.12.2009, 01:30 AM
Well it must be the MM ESC. Just plugged in the Quark 65a and both motors moved the mini just fine with no cogging. Looks like a bad ESC
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
08.12.2009, 07:42 PM
I WANT TO SE THIS VIDEO!
08.12.2009, 09:08 PM
Never heard of the Tenbol mount- got a link to the company/website etc?
