Its come! A world champion winning buggy with a twist... -
08.11.2009, 11:41 PM
http://www.hotbodiesonline.com/kits/en/67535/
I just hope the molded chassis holds up, but I am sure its gone through its paces during testing. Thoughts?
08.11.2009, 11:53 PM
I like the looks of it. but i wonder how the balance is.
and they have a 2200kv motor in a buggy- gotta love the overkill.
Mech brakes is an interesting feature. anyone plan on getting one?
That's All Folks!
08.12.2009, 12:00 AM
I LIKE it. I think that will be my next rig! My old buggy has been discontinued and parts are getting harder to find.
08.12.2009, 12:06 AM
2200kv in a buggy is perfect. I much rather that than the 2650. It ran so much cooler and seemed to have twice the power.
I love the look of this one. That body is sitting LOOWWWWW on the chassis. I'm not sure if I like the battery and motor on the same side. Seems off balance. Stock with Mechanical Brakes, im iffy on that as well. But this thing looks killer!!
08.12.2009, 12:18 AM
Meh, I'm not feeling it. Sure, it sits low, but I don't like:
- Motor and battery on one side. Might be hard to balance that.
- Pinion is wayyy too close to the battery for my liking. A good lawn dart and your lipos will be pinion fodder.
- Spiral cut diffs. Puts too much thrust pressure on the bearings. Probably quieter, but who cares really.
- Molded chassis. I'll take the extra weight and durability of a good aluminum chassis anyday.
08.12.2009, 12:42 AM
I like it, kind of.
Things I don't like:
Motor/battery on 1 side
Extra weight and rotating mass of mech brakes
Plastic chassis
Need long wires for motor-ESC and battery-ESC
08.12.2009, 01:32 AM
The balance issue actually might not be such a big problem if they could use a smaller spur, which would allow the motor to sit closer to the centerline. It's already got truggy diffs, there's no need for a 50t spur! Heck my Jammin CRT has those spiral cut diffs with a 46t spur, same motor (2200), 5s Lipo, and a 13t pinion. In that buggy on 4s you might need to gear it with an 18t+ pinion which would really push the motor out.
Keep in mind that balance isn't just weight related, but is a combination of weight and the distance from the centerline. If they shifted the CD more toward the right of the buggy and used a 46t spur they could get the motor pretty close to the centerline, probably close enough to negate the battery being on the same side.
I wonder if the 50t spur was included because they intend to have the owner use mechanical brakes? Otherwise that 50t spur option is simply retarded IMO.
08.12.2009, 03:17 AM
IMO they should have designed it to accommodate twin lipo packs.
08.12.2009, 09:16 AM
It will. Just stack them on top of each other.
08.12.2009, 12:01 PM
When is the truggy version coming out.
08.12.2009, 12:07 PM
My work filters this site... "hotbodies" is a "sex" site... lol
08.12.2009, 02:38 PM
140mm max battery length, same side of motor and close to the pinion? I don't like it...
Zippys won't fit!!
08.12.2009, 02:49 PM
i will get it. if its around $300
08.12.2009, 02:53 PM
I dont think it will be that cheap. I'm thinking around $400...
That's All Folks!
08.12.2009, 03:11 PM
Nitro version is about $300, don't see why this wouldn't be about the same.
