Wiring 12020 ESC question
Wiring 12020 ESC question - 02.11.2006, 10:07 PM
Quick question: I have the 12020 controller coming. Does this model use two wires for each motor phase? And if so, how do people stuff the pairs together in one 5.5mm connector so it's not crappy looking? I don't have the ESC yet, but if I need to get other parts, I'd like to know now.
FYI: I did a search and didn't come up with anything relevant.
coolhandcountry
coolhandcountry's Avatar
02.11.2006, 10:12 PM
Yep it does. I took and soldered one in and one outside the 3.5 plugs I used. I don't know about the 5.5 plugs.
Peace!
Country
Help support the
Rc-Monster
Buy here
02.11.2006, 11:07 PM
OK, thanks. That's kinda what I figured. If one wire fits in a 3.5mm connector, maybe two can fit in a 5.5mm connector. I guess if it doesn't, I can always do what you did. Does it look OK with one of the wires soldered to the outside of the connector? Maybe I'll solder the two wires to a short (1") piece of 8GA or 10GA wire and then that to the connector. A piece of car amplifier wiring should do the trick...
mmdooley
mmdooley's Avatar
02.11.2006, 11:13 PM
Hey, I got a 9920 with 4.0 to the battery and 3.0 to the motor. How do I get the two battery wries to hook to two battery packs with deans??
02.11.2006, 11:54 PM
What's "4.0" and "3.0"?
mmdooley
mmdooley's Avatar
02.12.2006, 12:06 AM
4.0mm gold connector 3.0 gold connecter
Superemaxx89
02.12.2006, 12:58 AM
whats your battery configuration? The one I used for that exact esc is this:
If any questions, ask.
mmdooley
mmdooley's Avatar
02.12.2006, 01:44 AM
I have the 7 cell hump pack. How do you post pic's sence they changed the fourms?
Superemaxx89
02.12.2006, 02:31 AM
open an account at photobucket.com
02.12.2006, 02:35 AM
Or, if you have a website and they allow direct-linking, use that. Also, many ISPs give you a little space along with your internet access. That's what I use.
coolhandcountry
02.12.2006, 09:37 AM
3mm connectors sound small. You talking the 3.5mm. You need to change the deans or the plugs.
Peace!
Country
Help support the
Rc-Monster
Buy here
Sylvester
Sylvester's Avatar
02.12.2006, 10:43 AM
Yea, deans would be best.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
Superemaxx89
02.12.2006, 03:29 PM
but thats to the motors. That is what schulze reccommends and uses, and that is what lehner uses.
coolhandcountry
02.12.2006, 07:46 PM
My lehners use the 3.5 mm and the schulze to. It is hard to modify the stuff cause it was made like that.
Peace!
Country
Help support the
Rc-Monster
Buy here
Superemaxx89
02.12.2006, 08:31 PM
mmdooley has 3.5mm on his motor wires...
