best 2.2 truck wheel for crt.5
boostedg60rado
best 2.2 truck wheel for crt.5 - 10.31.2009, 09:01 PM
Looking for a set of 2.2 truck wheels i know any 12mm hex works. But wondering what people have better luck with. I like the hpi scorch. They look sick in black. Also have thought about rpm revolvers for a traxxas rustler.
boostedg60rado
10.31.2009, 09:02 PM
Forgot to add i would like to get a but wider. Has anyone used the traxxas front wheel hexes to do so. I know there are wider than the stock crt.5 ones. Good idea isnt it. Well thanks for any input.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
10.31.2009, 09:08 PM
Proline 2.2's have one of the widest offsets
boostedg60rado
10.31.2009, 09:09 PM
good to know i am guess the agitator or something like that.
10.31.2009, 10:30 PM
I use these on both of my crt.5
slingshot front rims dyed black.. w/gladiator 2.2 tires
my CRT wheels
Doug Shelp
my CRT wheels - 11.01.2009, 02:05 PM
the wheels i made for my RCM.5 use the OFNA truggy dishes with the trinnity ultra firm truck foams i then cut 1/2 in from the width so they fit a buggy width wheel.then because i run on a track and almost never bash im using 1/10th truck double dees or hole shots.this combo gives a wide offset and the stiff foams hold up the sidewall in hard corners and my truck realy likes them
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
11.02.2009, 05:33 PM
I too am looking for a set of 2.2 truck tires so I can run some mashers on mine with a locked CD. I can't seem to find any wheels that specify hex drive and I know there are a lot that are pin drive which I don't want. I'm just lookin for some basic dish wheels.
11.02.2009, 05:36 PM
traxxas ell cheapo ones work
http://myatomic.com/catalog/viewsku?...e_2_2_nylon_2_
$3.09
snellemin
2 KiloWatt RACER
snellemin's Avatar
11.02.2009, 06:18 PM
I like the rear rustler nitro wheels.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
more details on .5wheels
Doug Shelp
more details on .5wheels - 11.02.2009, 11:13 PM
hey again ,a set of the OFNA truggy dishes "4ea" is about $10.00, the trinnity ultra firm foams are $7.oo a pair and they last for ever i just cut the sidewall out andpull them and wash them and ive reused my five sets atleast three times and they still hold the tires up fine and then what ever truck tire works for you.
Metallover
RC-Monster Spudgunner
Metallover's Avatar
11.02.2009, 11:40 PM
I have black rpm revolvers with gladiators. They look and work great.
boostedg60rado
11.03.2009, 09:15 PM
I wound up using these in chrome. With proline gladitors. They worked great.
http://www3.towerhobbies.com/cgi-bin...P=7#otheritems
I did go with the traxxas front rustler hexes. Had to swap out the pins with traxxas pins cause the ofna ones where to long.
The only problem i had was the axle on the traxxas car is a bit thicker than the stock crt.5 axle. so there is some play in there.
And after putting the front wheels which have a deeper offset and the hexes i only get about 1 1/2 to 2 turns on the wheel nuts so i might go back to the ofna hexes to see where it lands me. As i dont like not having threads into the nylon part of the wheel nut.
ta_man
11.04.2009, 01:48 AM
Use the Losi 12MM hexes from part number LOSA3260. They are only .175" thick compared to .235" for the Traxxas hexes. Plus they will fit the axle better because they are designed for that size axle.
boostedg60rado
11.05.2009, 10:01 PM
good to know thanks.
boostedg60rado
11.05.2009, 10:02 PM
well actually the play is in the wheel opening. not the hex drive. But i think it will be fixed when i get more bite with the wheel nut.
